fuel injector seal? O2 sensor? I guess worst case could be an intake manifold crack? Does the Ridgeline use any vacuum lines under the dash (i.e. on the AC housing)?
Hello Mr. Vazquez,Hello Elkhunter. Thanks for your suggestions. I not mentioned that I replace one O2 sensor, the ones nearest to the spark plugs, in front of the radiator.
Maybe take a look at the injector o-rings?
Let me investigate intake vacuum lines under the dash and an intake manifold inspection.
Arnoldo Vazquez.
Foxwell NT510 with Honda/Acura software
https://www.amazon.com/Foxwell-Mult...&qid=1530188423&sr=1-5&keywords=FOXWELL+NT510
Adding to my previous post. did a valve adjustment which got rid of the misfires replaced all vacuum hoses which got rid of the rich codes and and improved the fuel trim which was around -12 now staying around -4 to -7 ltft both banks. Still have the 2279 and an idle surge from 800toaround 1300 when I take my foot off the accelerator or when revving the engine. IAT ECT MAP all test good pcv was replaced but may be aftermarket. Also cleaned the throttle body off the vehicle with throttle body cleaner. Plugs are new coils are good. Bled the coolant system properly as well. Have done idle learn clear eco and throttle position learn. What next? Throttle body apps? Scratching my head. Replacing all the vacuum hoses definitely helped with the fuel trim but the idle is killing me.
It’s funny cause when you depress the accelerator with the key in the on position but not running the throttle opens as closed when you let off the pedal then opens just barely. That seems to correspond to the surge when it’s running. Wondering if anyone has come across that. When looking at the throttle position both relative and absolute on the graph it’s smooth on the way up and down but then comes back up slightly before stabilizing.
So this is fixed. The problem turned out to be a few issues combined. The valve adjustment and replacement of all vacuum hoses along with cleaning and the REPROGRAMMING THE THROTTLE POSITION VALUE. The throttle position value had to be cleared and then reset with the idle learn procedure. The most annoying thing about this issue is that once I realized the throttle body needed to be reprogrammed I contacted three dealers all of which told me there was no such thing as pushing a button and resetting the throttle value. Even though the Honda fsm clearly states this has to be done after cleaning.
I was so annoyed that I went out and for $200(likely less than my bill at the dealer would have been) bought a Foxwell NT510 with Honda/Acura software. This thing is unbelievable for the price. Very easy to use. Took me 15 mins to figure out how to clear the throttle position and reprogram and it’s beem running like new ever since. 300k and you can barely tell it’s running when idling in park or stopped in t traffic. In addition to the throttle reprogram it can also read all the other modules, AT, SRS, ABS, you name it, you can also actively test nearly every component on the vehicle. Definitely best value out there in bi-directional scan tools. As far as the dealers what can I say...they suck! What a rip off. This whole issue started off two years with them telling me I had a blown head gasket. I couldn’t believe it so investigated for myself after they quoted me $3500 to fix. They had replaced the radiator to the tune of $1200.
The new one promptly failed. They replaced it under warranty and then proceeded to tell me a crazy story about how it was causing pressure in the engine and blew the head gasket. So disappointed with Honda service. Even did multiple combustion gas test along with other head gaket checks. They make such a great product only to put some slackers in their service depts. I’m sure there are plenty of good techs out there working at Honda unfortunately not at the dealers near me. That said I’ll never take an out of warranty vehicle to a dealer again. So...valve adjustment is a must, if you have high mileage replace all vacuum lines they cost nothing and I found most of mine to have very small cracks which can add up to a leak and clean and reprogram the throttle. My truck feels like it will go for another 200k.
Hey what's you're email and where are you located? I'm in NC and I'm experiencing the range issues. I can use your helpAdding to my previous post. did a valve adjustment which got rid of the misfires replaced all vacuum hoses which got rid of the rich codes and and improved the fuel trim which was around -12 now staying around -4 to -7 ltft both banks. Still have the 2279 and an idle surge from 800toaround 1300 when I take my foot off the accelerator or when revving the engine. IAT ECT MAP all test good pcv was replaced but may be aftermarket. Also cleaned the throttle body off the vehicle with throttle body cleaner. Plugs are new coils are good. Bled the coolant system properly as well. Have done idle learn clear eco and throttle position learn. What next? Throttle body apps? Scratching my head. Replacing all the vacuum hoses definitely helped with the fuel trim but the idle is killing me.
