Did mine today according to maintenance minder at 9050 miles. There is not enough room for my socket style oil wrench to fit between the bottom of the filter and the structure of the car. Had to do the old drive a screwdriver through the filter for leverage trick to get it off. Also, the plastic fender liner in completely in the way of the filter. Our last Acura with basically the same engine and using the same filter had neither of these issues. I trimmed the flimsy ass fender liner slightly so I could access the filter. Its another on of Honda's brilliant remove the filter and it drains across the car's substructure to get to your drain pan tricks again as well.
