1 - 5 of 5 Posts
I noticed that the compression ratio on the V6 is 11.5 to 1. The owners manual calls for regular gas. Are there any problems running regular gas in these engines?
I'm going to have quite a few rookie questions over the next few weeks. Thanks in advance.
Owners manual recommends unleaded gasoline with a pump octane of 87 of higher. I have always used 87 in mine and never noticed an issue.
Good question. We have other vehicles with 10.25:1 and 11.00:1 compression ratios, and both require premium. Guessing there's more to it than the CR?
2018 RTL-E
Ive always used 87 except once while traveling. I was at approximately 5000’ elevation and didn’t notice that the lowest grade fuel was 86 until the tank was full. It was probably in my head but the truck seemed slight low on power so when the tank got down to 3/4, I refilled with premium and it was back to normal.
Ignition timing, combustion chamber design and valvetrain operation (e.g. - camshaft lobe profile) can all play a significant role in required octane vs pre-detonation.
Many modern engine designs allow the timing to be automatically advanced when the ECU senses that higher-octane fuel is used, or, more correctly, retards the engine when it senses pre-detonation associated with lower octane.
The 3.5L engine in the G2 Ridgeline has not been shown to take advantage of higher-octane fuel under normal.conditions. In the G1 Ridgeline, higher-octane fuel was advantageous in allowing the torque converter to remain locked up for longer periods, especially while towing. This would reduce heat/wear on the transmission. It is reasonable to assume that the same thing would happen with the G2, although there is likely more logic built into the G2 trans and ECU, and also likely varies with the newer ZF9. Perhaps someone more knowledgeable will chime in here...
1 - 5 of 5 Posts
