1 - 3 of 3 Posts
I noticed the other day that I was not able to select the AUX input on my stereo. When I jiggled the cable going from my phone to the jack, the AUX input mode would appear for a second or two then disappear.
After some research, I discovered that the problem is inside the 1/8" connector, specifically that the input cable was not being detected.
Solution is to take the jack apart and solder or otherwise connect/jumper two of the pins on the pcb.
I did the soldering and now it works perfectly.
With the original configuration, the AUX input would only be available when a cable was plugged into the jack. Now, the AUX input is available whether a cable is plugged in or not. Not an issue for me and saved roughly $40 by not having to buy a new jack.
400734
400735
I just bought an 08' RTL a few weeks ago and had the same issue with the AUX input. If someone doesn't have a soldering iron or wants to retain original operation, you can just replace the pcb (circuit board) pictured above with one from another honda aux input.
I got one on Amazon for $12- part number ( 39112-SNA-A01 ).
Just disassemble the purchased AUX input like the one in your Ridgeline and swap out the pcb and your done.
5 min job. I was surprised at how easy it was to take the jack out with a flathead. I thought I might have had to get to it from behind the dash.
I like Mike's solution but I have messed up my share of circuits trying to solder with my less than impressive fine motor skills so I here's another way to skin that cat and save a few bucks.
Good to know about the replace pcb option. I saw a video of someone who, lacking a soldering iron, just inserted the right size screw between the two posts and it accomplished the same thing. Just need a way to jumper or otherwise connect them and good to go.
1 - 3 of 3 Posts
