1 - 20 of 53 Posts
I'm 60 miles into my 2nd tank of gas. I have a 2022 black edition. Love the truck. I put 367 miles on it so far 235 are on the Mass turnpike. Eco has been on since 30 mile mark. I am averaging 14.3 mpg. Got as high as 15.1 on highway. HELP.
Try running ethanol free gas(also known as recreational gas). It can be a little difficult to find and cost about a dollar more. Ethanol is awful for any engine. My gas mileage starts to drop time to time. I’ll run two tanks of ethanol free gas and the motor resets and I get all my mileage back.
· Premium Member
Please back up your claim with some verifiable facts.
The EPA estimate is at 55MPH - on the Mass Turnpike 80MPH is the norm and 15 mpg sounds right.
2022 RTL-E Obsidian Blue Pearl
That does seem low. I have a 2022 rtl-e and my trip-meter computed average (non-Eco mode) with 6,000 miles is 20.3 mpg with about 1/3 stop and go, 1/3 55+ mph secondary roads, and 1/3 70 mph interstate.
That is an excellent point - I would suspect that fuel mileage drops a LOT as the speed increases above 55 mph. It depends a lot on your actual speed on the Mass turnpike.
· Premium Member
2019 RTL awd, MSM
Not quite. You don't give your gubmint enough credit:
Also, they updated their testing criteria several times over the years, so you can't compare your MPG on your current vehicle ratings to the ratings on a vehicle that's a decade or so older.
2017 Ridgeline RTS AWD, White Diamond Pearl
I'm 60 miles into my 2nd tank of gas. I have a 2022 rtle black edition. Love the truck. I put 367 miles on it so far 235 are on the Mass turnpike. Eco has been on since 30 mile mark. I am averaging 14.3 mpg. Got as high as 15.1 on highway. HELP.
You didn’t specify exactly how the truck is being driven, so there is no way to say whether that mileage is normal. Most of us wouldn’t know the conditions of the Mass turnpike or how heavy your right foot is.
I just pulled a 6x12 enclosed cargo trailer for 400 miles with my ‘17, and the dash display says average for the trip was 16.4 mpg.
IDK—the only way I am going to get down to 15 mpg is to pull a 4000# trailer. I’ve gotten 20-21 consistently for the last year with mixed driving for work. I use 10% ethanol 89 octane. And I rarely use Eco.
If that info is from your trip computer, I’d recommend calculating it yourself over a couple of tankfuls before rushing to conclusions.
It's a brand new truck, it will get better, but 15 is low, even doing 70 to 80, unless it's all uphill.
From my experience, I can get better MPGs than Econ mode, so I never use it. Don't jam on the gas and wind it out, let the gears shift up, I try to keep it around 2000 rmp, cruising at 75 mph. Obviously it will go higher when getting up to speed, but gradually.
Prestarting puts a dent into your gas milage also, whether it's to cool it down or heat it up in the winter.
And, don't be one of those drivers that think you should be on the gas or stomping on the breaks at all times, nothing wrong with coasting.
The point is, everyone's driving habits are different, so hard to say for sure, but you should be doing better.
I get 22-23 overall avg. 50% short tripping around town, 50% open road, that's on 87 oct reg w/ethanol. I don't have as heavy a foot as I used to and don't jackrabbit very often, so? And I NEVER use ECO button and ALWAYS turn off auto shut off.
2021 RTL-E Modern Steel Metallic
I'm averaging about 24 MPG's overall after 16,000 miles in my RTL-E. I just registered 32 MPG on a 250 mile stretch of driving on 2 lane highways in the Upper Midwest (typical highway speeds 60-65). The only time I've gotten lower than 20 MPG for an extended drive is while towing.
22 RTL-E here as well. I'm on my 2nd tank of gas. I'm in ECO mode, city driving 25-50 mph everywhere. AC at 68 usually half speed or less. Typical driving to grocery, ball fields etc. No towing. No aggressive driving (2 kids in the car usually). Using Costco 87 octane. Computer is telling me 15.6 mpg. I'm hoping it gets better as the truck breaks in.
21 RL RTL-E Silver
I never saw 15s in the tank avg on my 2021 RTLE. Since new has been 20plus. I am not using ECO.
The lowest I saw was 19 due to the drag created by a full 4-bike hitch rack.
The typical MPG avg displayed on mine is 22mpgs at the end of every gas tank.
Driving style really affects the numbers doesn't matter if ECO is on or off.
My 22 was pretty low, 18-19 mpg, for the first 4k miles. Started to creep up after that and now with 7k miles I'm about 23- 24 mpg overall, rural driving mostly. No long highway trips yet. Initially I hand calculated but for me the indicated mpg was very close, within 1mpg, so why bother.
My average is around 15 mpg and I have 3500 miles on the odormeter. Went up to
My 2022 RTL-E have 3895 miles and my avg. is 15.8, I also carry around 500 pounds everyday
· Premium Member
Straight from the US department of Energy website;
Denatured ethanol (98% ethanol) contains approx. 30% less energy than gasoline per gallon.
So if I do the math correctly, and you are using E10/E15, that would be an approx. energy decrease of 3 - 4.5% / gallon. However MPG really depends on driving habits. I have only ever run 1/4 - 1/2 a tank of it through my engine, Therefore I do not have any personal experience with the subject.
1 - 20 of 53 Posts
