1 - 20 of 28 Posts
Anybody have any success with aftermarket hitch lights or other lights to brighten up reverse?
New tail light bulbs haven't solved the issue.
If not using the camera it's hard to see out the rear/side view mirrors when going in reverse.
Maybe it's just old age....
Thanks
Might try the Putco tailgate light bar. It has a white light mode in reverse.
Thanks
FWIW- replace the backup light (filament bulb) with an LED bulb - less than $10 per set and much cheaper and faster solution that adding an LED Light strip. I did this and now my backup light is 3x brighter. BTW - I also have an LED light strip under the tailgate. Replacing the factory bulb was a better solution for me.
I just ordered a set. $6.99.
2011 VP Bali Blue Pearl
I used these on my G1. Work quite well.
399701
2019 Sport Lunar Silver
That link shows a dual element light, also saying do not use for back up. This works for a back up light?
Geeze, those SuperBright's are $15.00 (US) each.
Nevermind I see the Amazon (which I think are the same) are only $13.00 each.
Thanks. Nice $7 mod. Works great
Wow, I bought these (see the post in front of this) back early January and never got around to it, figured meh how much better can it be, well I’ll tell you a TON better, I can’t believe the difference.
1 - 20 of 28 Posts
