Hi all,
When this first happened, I assumed it was a bad camera and replaced it, but now I'm on number three of different brands and models, so it's gotta be me as opposed buying three broken cameras.
I have the power cable connected to reverse lights. I tested with a multimeter that it gives 12.8 volts when reverse is geared. So the power cable seems ok. I then tested the video cable by using a different source, a VCR, starting at the back where the camera would plug in and resulting in 1.18V in the cab. So the video cable seems ok, too. Now, when I plug in the cameras into both the power and video cables, nothing happens. I get 0 volts on the video cable in the cab. I even bypassed the long video cable and tested the voltage directly on the camera's output, but keep getting 0 there. What the heck am I doing wrong? It's not making any sense right now. My original assumption was the camera device was broken and it wasn't transmitting a video signal. However, three brand new devices later, I'm starting to think it's me, not them.
Any ideas?
Thank you,
Peter
Any ideas?
Thank you,
Peter
