If it was my decision to make, I would most likely put the money into my truck since it is paid for and still in good shape (only 33,000 miles).
86,700 mi. S.T.U.V., took it off road a little when I first got it, nothing heavy at all I haven't had it off road in about 7 years strictly city streets and highways. Kind of surprised that it's bad too.How many miles on the ridge? I heavily offroaded my ridge and didn't replace the factory control arms (balljoint) until about 160k... And it wasnt even the ball joint that was bad it was the bushings.
After looking at various trucks, and how much they want for new one's I think I'm also going to have the tie rods done , ball joint replaced and the timing belt done and keep it a few more years like you. I do love this truck and there really is nothing like it. Also been looking for a decent 2014 with low mileage but they are hard to find.Within the last 6 months I spent around 2500 cause of issues with the new RL and not many around. I still like mine so new tires, timin belt along with many other things related, new tie rods both sides and alignment. I know I wont recoup the total cost but in the mean time I have a piece of mind and wont be afraid to drive it another 5 years. And might sell faster for a bit more then one that has had nothing done. Still waiting for Honda to build that other truck.
When you do the timing belt/water pump service, remember the serpentine belt and tensioner pulleys too.After looking at various trucks, and how much they want for new one's I think I'm also going to have the tie rods done , ball joint replaced and the timing belt done and keep it a few more years like you. I do love this truck and there really is nothing like it. Also been looking for a decent 2014 with low mileage but they are hard to find.
Most of the other things that you mention I will do myself and save tons of money over the dealer however I don't have a lift or an alignment machine to do the ball joints and tie rods and the timing belt I'll also let the dealer do, if they mess it up it's there dime.When you do the timing belt/water pump service, remember the serpentine belt and tensioner pulleys too.
Also the hydraulic tensioner (which should be part of the timing belt kit).
Spark plugs.
PCV valve
valve adjustment
radiator and coolant
It won't be cheap, but it will be cheaper than buying another vehicle.
Thanks, A friend of mine is also going to check out the front end to see what is wrong. As I said before I do find it odd that the Ball joint is bad with only 86k miles on the truck and it not being driven off road in a long time.I would get another opinion on this one or at least have them demonstrate the issue with the vehicle up on a lift. If the clunk is still there when they are done, then what?
Plenty of people reporting front end clunks on this forum yet few if none have had the ball joint as the issue. Clunk sources that I have seen: Sway bar bushings, sway bar end links, upper strut bearing, compliance bushings, engine mounts . . . The compliance bushing on the control arm does tend to wear out but the ball joint seems very reliable.
My clunk was the one inner Tie Rod. Easy to find just crawl under and grab them and see if theirs play. But I replaced all cause I have 108,000 miles on it. If you just replace one out of the four your talking lots of money in alignment jobs.I would get another opinion on this one or at least have them demonstrate the issue with the vehicle up on a lift. If the clunk is still there when they are done, then what?
