Is anyone else having a problem with a banging noise is the front end when turning the steering wheel, i get it allot pulling out of my drive way and making slow right and left hand turns, if you have what was the problem causing it.... Thanks Ryan
Do you have to be turning to hear it? Mine makes the sound as I pull out of my driveway. I have tried several different things. It happens only when I ambigridge said:Is anyone else having a problem with a banging noise is the front end when turning the steering wheel, i get it allot pulling out of my drive way and making slow right and left hand turns, if you have what was the problem causing it.... Thanks Ryan
yes, mine does the exact same thing......only in the mornings when i pull outRRPRTS said:Do you have to be turning to hear it? Mine makes the sound as I pull out of my driveway. I have tried several different things. It happens only when I am
pulling off, after being parked. It doesn't matter if I am backing out first or not. Some one suggested it may be the ABS self check. I have not taken mine in yet.
Please let us know what the dealer says or does.
Thanks
good point ebone.........i wondered if the two were related. i noticed the locksEBone said:gormlyflyer 2002 - I have the same noise, however, it is followed immediately every time by the auto door locks engaging. I'm wondering if it is some kind of transmission sensor that activiates at 9 MPH and tells the door solenoid locks to engage.
