Still awaiting my RTL as it was scheduled to be built in the next few days. I did get more info on the radio swap as well as my Pioneer AHV-4100NEX head unit, metra wiring harnesses for the 2015 Civic and steering wheel control interface.
SO after more digging, I found the civic audio wiring connector pinouts and compared them to the 2016 Pilot ones. As I mapped them, I found there are only about 6 wires in the correct spot in the 24 pin civic connector. This is not a direct plug n play deal (but I am fully competent and up for the challenge). I wrote down which wires needed to go where on one of the two the civic connectors to be able to become a plug n play. This is the main audio connector that provides power and speakers from the head unit.
The second large connector is a 24 pin in the Pilot, but a 32 pin version in the civic. This will not be able to be used as is, but we will just need to cut the insulation on the factory harness and solder the wires where they go,. There are other creative ways like to dismantle the stock head unit and take out the connector block plastic to hold the wires/pins removed from the 32 pin plug we can't use. I'll see what I feel like when I get in there. WHo knows, maybe Metra will come out with teh proper connector by then. I have not called them...
SO this 32 pin connector on the civic (24 pin on the Pilot/Ridge) really only houses the camera. You need 4 wires and that gets you the camera video and power. Unitl someone can figure out the Bit 1 and Bit 2 signals that tell the camera to change to the three different views, you will be stuck with one view only for the reverse.
You WILL lose ANC or Active Noise Cancellation. Reading about this in the Pilot forums, there are peopel who like it and many who don't. This uses the radio and some dedicated (non phone/bluetooth) microphones to monitor the cabin sounds. The radio then sends out an opposite sound signal cancelling out the noise. This is only effective on constant wind or engine noise. SOme people get feedback in their ears when playing certain music or if a window is open so it is not foolproof. It will go away with no ill effects other than a little more road noise if it is not hooked up. Your music may sound better as the speakers are now only being used for music rather than music and noise cancellation frequencies.
I know another person mentioned the Can Bus wires that go through the radio. According to the Pilot audio connector pinout, there is Can Bus High and Low wires in there. On the civic forum, they too have these wires and no one had issues with not hooking them up.
Another plug for the Pilot is for the USB connection. This is like a USB B plug typically found on printers. It would be the square plug with two angled sides. The Honda plug may or may not fit a USB B plug. Need to try it. The only issue would be that there are no angles to ensure the plug is turned the right way like the USB B plug has. If it fit, you would need to secure the plug in so it did not fall out and then don't remove and rotate it by accident later. The safer option woudl be to just use the USB cords that come with teh new aftermarket head unit and run them wherever you need and don't bother with teh Honda connector.
The radio antenna plug is easy as Metra makes a plug for that.
The last one is the 12 pin audio plug shown on the Pilot pinout diagram. It deals only with GA-Net. This is like the IP-Bus in a Pioneer or other audio brands. It is a data bus used to communicate to other audio sources. Not sure that this would need to be connected at all. The Ridge does not have a factory DVD player liek a Pilot, and you can use the Axxess Steering Wheel control interface to automatically decode the steering wheel signals and sent them to the aftermarket head unit. To me it would seem that this GA-Net connector does nothing above that for the base radio.
The Metra mount kit for the radio looks really nice. It is for the Pilot and I got the gloss black. There is a textured black one as well.
More to come as now it will be a waiting game to get the unit installed in my Ridge when it arrives
