How does a reduced load on the alternator increase MPG?
All I can do now is wait a few months then check the resting voltage with a Multi meter. I have to assume the dealer checks the Alternator output prior to replacing the batter. I suppose I can check that also with the multi meter, withe and without the lights based on your information, thanks for the help, much appreciated.
You can get a newer version battery tester like the
Solar BA9 or like it. It's what most places use now that tests capacitance I think in the battery. You can also watch the video on YouTube for
Kent Bergsma he goes over a bunch of the old tests and new. It's nice that you can check and know that your battery is dying to plan ahead not be stranded.
From there you can also get into the project farm on battery tests and on portable jump starters, or carry old school cables IF you can find somebody willing to help these days.
I have one of CTEK smart chargers (also from the Kent Bergsma videos as well as Optima battery recovery one). My wife's old Sequoia with a big Optima 31M deep cycle would start to crank slow and needed a charge at least 2x per year. 90% of her trips were less than 5 miles and not long enough to give it a good charge.
And NEVER ASSUME, you know what happens. Best to check battery after sitting at least 8 hours AND if possible do that with opening doors etc. leave hood open and keep keys away as it will "wake up" many things as key gets close.
If you find an issue you'll need to watch/read how to do a parasitic draw test to see what is killing it. My daughters CRV had a bad AC relay which is a known issue.
Reduced load on alternator reduces the load on motor for a .00001% or something like that increase in MPG just like they are going to 0W-16 motor oil. All in the name of drag/load and CAFE MPG standards. What are the 9 most terrifying words in the English language?
