I am the original owner of my 2006 RTL with Navi. I've been on these forums since 2006 and have found tons of valuable information in that time.
I feel like I've always had a bit of a battery drain, but in recent months, it has gotten much worse. It had gotten to the point where one or two nights of not driving the truck would result in a dead battery.
Friday night I got out to the truck with a multimeter and tested AMP draw on each of the circuits. I found that the radio had a .58 AMP draw when the vehicle was off. Disconnecting the radio by pulling that fuse, After pulling the fuse, the draw then was within acceptable limits. The NAVI was not the problem, but the radio portion below the NAVI.
The questions are:
Does anyone know what it is within these radios that causes the draw? I.E. is it something servicable? I'd rather not go through the hassle of putting in something aftermarket or buying a used one knowing that this has happened to others with Honda radios.
Is there someone that can reliably repair these OEM units?
The questions are:
