That's not the correct part number. The correct part number is 31651-TZ5-A02 for the 2017-2019 Ridgeline and 31651-TZ5-A03 for the 2020-2022 Ridgeline.
ThanksThat's not the correct part number. The correct part number is 31651-TZ5-A02.
Thanks for your response!Sorry I am late replying to your post, but listen... I have had two RLs since 2005. Minus a break for about 2 years between Gen 1 & Gen 2, that's 14 years. Zero issues other than a back seat plastic cam failure and a RF headlight that burned out after about 5 years. Seriously, other than oils and a timing belt (that I pushed to 11 years vs 7/9 on Gen 1), I have had nothing go wrong. And even the timing belt is a known wear item.
Yes, it sucks when you have issues, but it's real life. Mechanical things fail. If only I could help people understand HOW MANY brand new, off-the-shelf parts failures I have seen in my short life...
Well, that depends on who you ask. To some, I'm a wart on the face of society.@zroger73, you are a national treasure sir!
I climbed into my truck a few days ago and received these codes. Truck has 120,000km on it. Honda Canada says the part is backordered. They want $183.36 for the part and $59.98 for labor to install it.
Now more than a month installed a new blower fan original Honda's part.Now since two days warnings are gone!?
Seems the contacts and cleaning did some good. Still weather here was warm.
Got the replacement fan blower on order until it arrives.
Just hope I don't get any other stupid sensors, bad connectors.
Have the exact same issue wth my 2017 Ridgeline. Honda dealership have confirmed it's the battery cooling fan (after a $300 diagnostic session!). Replacement part is $500 CDN + labour! Brutal....but apparently no way around it...too many sensors/electronics these days!!New to the club so apologies if I've missed the answer to my question within another post. 2017 sport built 11/16. VIN 18928 so not specifically in harness recall. Out of the blue the charging system and AWD lights came on. AWD definitely not working but no issues discernible with charging system (I've had alternators go bad so I know what that looks like). And I've been driving it for the last few days without problems. Took to dealer today and was told the battery fan failed and it's the root cause of both. Anybody heard of that?
Same happened to my 2017 over this Christmas. Never knew battery had a separate fan. The way the battery is enclosed makes hard for air to circulate without a fan. Anyone know of a way to by pass all the plastic around the battery or maybe tried something. Dealer says there’s no way, but that’s what I’d expect from a dealer.New to the club so apologies if I've missed the answer to my question within another post. 2017 sport built 11/16. VIN 18928 so not specifically in harness recall. Out of the blue the charging system and AWD lights came on. AWD definitely not working but no issues discernible with charging system (I've had alternators go bad so I know what that looks like). And I've been driving it for the last few days without problems. Took to dealer today and was told the battery fan failed and it's the root cause of both. Anybody heard of that?
