Optima Yellow Top.
Less than 1 year old.
Truck last driven mid-day Sunday 1/8
Measurement taken 1/11 8 AM
12.29 V = state of charge approximately 65%
Keep in mind rate of self discharge + parasitic drain is not linear, meaning 35% below 100% after 3 days does not mean batt will decline ~10% /day.
Thanks for this! And the previous post, the link shared is very informative for the ones wanting to know and understand better the Honda charging system. The charts will take me some time to analyze and understand.
I tend to think, just like it was mentioned on the link that anything connected directly to the battery will not make the charging system, react or maintain a voltage above 14V, since with 1/0 gauge wire and 3 amps on and playing loud, the ELD won't kick to high Voltage charge and stays at 12.6-7 volts.
I get, 12.3 V rested voltage after a day or within 24 hours, after 20-25 min of city driving the previous day, if I drove it for longer than 30 mins, I get 12.5V, and 2 plus days without driving it, just 12.10 V just recently and about 45 degree temperatures at night.
It's within the normal range for thiese trucks, I was worried that dropping below 12.3 was not OK, but it may be normal, sometimes when I park outside I only activate the alarm for 8-10 hrs at night, and that does not seem to help much with the readings, the drop after a full charge has to do with the electronics and constant voltage needed for clock radio memory and other accessories computers etc, that need the power.
Let's hope to get some more readings at different times from other owners, just to see if trucks with full factory equipment and no external amps offer similar readings.
Got a tip, not sure it will help but I will continue to use it on my short trips. Blower motor on, and parking lights on, keeps voltage at 14Volts, at least I do not have to have only the headlights on, and reduce their life, I'm not sure I will extent the battery life beyond 6 years or make it worse, the best way is to drive it for more than 30 mins every day would me my guess, since I got 8 years minimum of battery life with older cars and driven over 12000 miles per year, and much older, pre 95, my guess is if batteries back then took a constant 14 volt charge, and lasted that much for my area, maybe that extra step with this truck, may help to get an extra 2 years out of the batteries.
One thing, if I plan to not drive it for more than 3 days, i may leave a smart charger or float charger connected to it.
