1 - 20 of 31 Posts
I am looking into the bed extender. I have checked out other postings about it...and have seen both positive and negative comments.
I don't see any advantage to it (at least not to justify the cost)...but am new to owning a truck...so I admit I could easily be missing the advantages of it. What does it do that I can't acheive with straps?
Is the OEM extender the best solution? The "angles" on the corners of it seem to cut down on the bed space available.
Guess that it all depends on what you're hauling! ;) Mine spends most of the time in the garage (whereas my bungee cords and tie-down straps are always in the trunk) but at times it has come in pretty handy.
Pros:
  • Once the brackets & snaps are installed it's very easy to mount/dismount and equally easy to use.
  • Easiest way that I know of to haul something bulky (bags of mulch, firewood, boxed cargo, etc.) that might want to slide out without having to tie it down.
  • More secure than tieing down with rope or bungee cords.
  • Fits under a BakFlip (and, I presume, other tonneau covers).
Cons:
  • Way more expensive than rope or ratchet-style tie-down straps.
  • Have to dismount to open the trunk.
  • Limits the length of what you're able to haul.
  • I wouldn't trust it as the sole means of holding something really heavy.
I have the OEM bed extender and mine also spends the majority of the time in the garage. It came with the truck so I wasn't going to turn it down but it likely isn't something that i would purchase on my own as I've only used it a couple of times. I guess it just boils down to what you're hauling.
I have a bed extender and a Truxedo tonneau cover. I use them both all of the time.
What I like about the extender:
- Easy to remove and re-mount.
- Makes a great 'trunk' under the Tonneau cover for groceries and other shopping trips
- Easily flips over to haul/hold longer items
What I don't like:
- I have to roll up the cover to get it out to access the trunk.
I think I'll keep them both ;-)
I have the OEM tonneau and bed extender. They complement each other in providing security and a ready to use "compartment". I don't have to futz with stuff rolling all over the bed.
I am very glad to have both with my RL. It "extends" the practicality of my RL (no pun intended).
I'm not a weekend handyman kind of guy; unlike many other members on the ROC. I'm not likely to haul sheet rock, plywood, mulch or anything likely to cause a bead of sweat. I do keep it in the bed at all times.
When needed, I moved a IKEA sofa; moved daughter from university housing to home, back to university housing, back to home, back to university housing; moving miscellaneous stuff from the house to the storage facility; moved the daughter to her first apartment after graduation; helped moved brother-in-law to condo. You get the picture.
I got the Pepboys Extender when they were having a blowout sale and only paid $39 for it. Still I don't use it very much and it spends most of it's time in the garage with boxes stacked on it. I just have to find a clean way of mounting it in the back of the truck so it doesn't interfere with the trunk.
Agree with the posts in this thread.
I have the OEM one too. I like the functionality, including being able to mount it behind the cab (though I haven't used that feature yet). It is overpriced, though. And will live in the garage for the rare needed occasion.
It was perfect for when I bought new a twin mattress for my daughter's bed: the mattress and box springs fit perfectly in the bed snug to the extender, no tie downs required.
I have used the OEM Bed extender a few times.
I have used it when the BBQ Grille has been put into the bed of the truck.
Also when I got some indoor outdoor carpet I put the bed extender on for use. I have used it in the forward front positon once when the Tonneau Cover was off it did a nice job of keeping stuff in secure in the bed.
Like said it depends on whhat your hauling at the time.
Moderator
I use mine a lot. It is like a second line of defense when you sorta over cram the bed with crap.
I use mine all the time.It stays in the back,when not in use I'll just flip it over and close the tailgate then i have a place to put small item and they don't roll around the bed.It comes in handy when hauling long pieces of lumber,plywood,Sheetrock,ect.yea I use my truck as a truck and one of the best add on is my bed extender.I believe the bed extender that angles out is for motorcycles.
If I lose a tie-down, My hope is that the bed extender will keep the scooters in the bed until I can get over to the side of the road.
In my many years of hauling bikes, I've never lost a helmet bag, ice chest, camp chair or anything from the bed of my trucks. It may only be just "piece of mind" but you really can't put a price on that right? :)
No one can ever accuse either of you of being afraid to use your trucks to actually haul "stuff"! :rolleyes:
I can get a lot more camping gear in my Ridge' when I use the extender and it just feels more secure than when I've used the platform that fits into the hitch receiver. Be very careful when you install the brackets, I stripped one of the 3 screws and had to rely on the other two to do the job. :mad:
Great for extra security when hauling the JD and worth $39. Bungee to the front tiedowns when trunk access is needed. The front brackets would be nice but not necessary.
Oh man, you aren't kidding. Rear brackets are a pain. The right side 3 are almost all the way in, but the lefty has just 2, like yours.
You'd be surprised how much it comes in handy. I use mine all the time. It never fails, you will always need a couple more inches...
5S Dude,
I see the bed extender you have looks like the oem standard one. When I purchased my RL the salesman ordered the same one you have. My problem was., when I loaded ours bikes the bar would not fit around the bikes. I had him reorder the motorcycle one. Now, it fits with just a lil pushing in on each rear tire towards the middle. Looks like yours fit ok!. Is there another different bar extender?.:act002:
Not only is it good to use it when your bed is open, it works great to create a little space against the inside of your tailgate and the extender. I used mine that way a lot on my Tacoma. That's where I used to put my groceries when I went shopping and it would keep 'em in their place. Also good for other things. It kept a lot of things from sliding all around the bed whenever the tailgate was up.
I don't use the bed extender too often, but it has come in handy on several occasions. I used it today to take some things be recycled. I had to replace the dishwasher, and called to see how much it would cost to set it out with the trash...$35.00. I found a local recycling center that will take appliances etc. A trip to them and they paid me $10.00 for some wore out items.
as DLIT said, not only is it good to use when your bed is open, it works great to create a little space against the inside of your tailgate when its closed.
1 - 20 of 31 Posts
