Wanted to share with you guys a bed rail I added to the G2 with a tonneau cover. Looks nice and doesn't get in the way of anything. One issue is that it's recessed a little too much so the side walls can block something you're wanting to install.
Because I had to remove 4 brackets for the tonneau cover, I used them on the bed rails. I plan on putting a J hook on next.
Not sure how popular this can be so let me know if you guys want me to post instructions.
Update:
Here's the instructions, I got most of it from a Tundra DIY and just worked it in based on Ridgeline specs. - https://www.tundras.com/threads/diy-unistrut-bed-rails-cheaper-option-than-oem.1906/
Parts:
Rails-Unistrut
Unistrut from a local hardware store. I know Home Depot carries these in the electrical section. I did 44-1/2" long in each side.
Installation Hardware:
(6) M6 x 1
(6) 1/4" fender washers
Mounting Hardware:
3/8? Unistrut channel nuts or cone nuts
3/8? Hex Head Bolts (length depends on what your attaching but I used 1" for the d rings)
3/8? Lock Washers
3/8? Fender Washers
Tools for Mounting:
Torx T30 Bit
Screw driver, ratchet or impact driver that can fit a bit.
Bed Rail Installation:
Before you install, be sure you know what you're doing and have all the correct tools and part. Safety is the biggest concern so please have all safety equipment for your safety.
Step 1:
Cut the unistrut to the desired length. Mine was cut so I still have a gap on both ends, but after installing it, I can tell it doesn't really matter if you leave a gap or not.
Step 1.2:
Paint the rails if desired - the paint does come off easily so it's up to you.
Step 2:
Remove the existing bolts from the bed with a torx T30 bit.
Step 3:
Line up the holes to see if you can screw the bolts in. I had to drill another hole for the center bolt and that got a little messy because it right next to a unistrut hole.
Step 4:
Once everything lines up, march the washer holes then the bolt through the washer, screwing it in to each hole until it's tight.
Repeat steps 2-4 for the other side.
At this point you're done with the rail installation.
Mounting Accessories Installation:
Step 1:
Slide the unistruit nut(s) on to the rail in desired location.
Step 2:
Place the accessory bolt holes aligned with unistruit holes.
Step 3:
I put the locking washer between the accessory and unistruit nut, then the washer and finally screwing in the bolt.
Step 4:
Tighten the bolts
If you want to move the accessory, just loosen, slide and re-tighten.
Update:
Parts:
Rails-Unistrut
(6) M6 x 1
Mounting Hardware:
3/8? Lock Washers
3/8? Fender Washers
Tools for Mounting:
Torx T30 Bit
Step 1:
Step 1.2:
Step 2:
Step 3:
Step 4:
Step 1:
Step 2:
Step 3:
Step 4:
Tighten the bolts
