Question:
I'm planning to replace a 2011 Ridgeline radiator, but need advice on which brand to use. It seems that most owners dislike the factory unit because it corrodes and fails, so I'm trying to get something that would be better & last longer. Some brands that I noticed were Spectra Premium and CSF brand.
Background info:
At a routine service visit, I was told that 2011 RL needs a new radiator. The service tech shined a flashlight down along the drivers side end of the radiator, and pointed out a small, barely noticeable blue-green stain at the 90 degree junction as the bottom of the radiator.
I was told that the radiators get "stress cracks" in Ridgelines & Pilots, & that it requires a new radiator. He didn't mention anything about the fittings or corrosion. He also said that he smelled an odor of burning radiator fluid. The price for this repair including the tranny flush was estimated at $800.
At home I used a mirror & flashlight at night to really try to inspect the fittings & the area down along the bottom of the radiator. The radiator seems fine to me, but after reading all the horror stories about corroded fittings, I was thinking that maybe it's a good idea to just do it & get it over with. I checked the tranny fluid & it all looked great, no signs of coolant mixing with tranny fluid.
The service guy said that the factory OEM radiator is the best & that they corrected the corrosion problem...but on further research, I could not find any evidence that the problem was ever corrected. It seems that they are using the same old radiator that gets the corroded fittings.
I'm getting ready to replace the radiator, but I'm just curious what is the best one to get, or are there a few that are comparable. It seems that the Spectra Premium & the CSF brand are very similar. I'd like to get the best one available & do the job right, to postpone this kind of thing from happening again anytime soon.
Any other tips about replacing other parts, hoses, hose clamps, etc. tranny flush, would be great. I'm not a mechanic, so I was planning to bring an aftermarket radiator to the Honda service center, have them do the install, and then do my own tranny flush later at home.
I'm trying to save $$, but I don't trust myself to do the install myself, & I'd rather pay to make sure that the hoses get all reconnected properly, & if anything else gets broken or missing in the process, then the service center will have everything there to complete the job.
I've done the tranny flush before, & I'm working on a few different places for prices for the radiator replacement. I assume that the Honda service center has the most experience with replacing a Ridgeline radiator, but a local radiator shop could probably do a successful job for less $$, & since I'd be doing the tranny flush, it might not make any difference. I'm just not sure about the tranny fluid cooling lines and the radiator cooling lines contaminating each other...I'm not sure if a local radiator repair shop would understand about not contaminating the tranny or mixing up lines etc.
Any advice or experiences would be greatly appreciated, Thx.
Background info:
