So I know nothing about lifting, off-roading, etc. My question is can I just put a slightly bigger tire on the existing rims for the new Ridgeline to achieve a little lift?
Thanks, guys.
Thanks, guys.
Yes there is but I'm not sure where they are right now.New to the forum and I am curious about the rubbing of the tires at the auto shows. I know they put a larger tire on at the reveal but didn't realize it rubbed. Are there pictures of the tires showing the rubbing issue?
I use my Garmin for speed, more important is youll have a slight different shift pattern. I didnt catch the size of the tire showin on the new RL but if it was fatter i could understand the rub. But if its 1" taller and same width it might be ok for that whopping half inch extra clearance. When my 245 70R 17s need to be changed out on mine they are close to the same size as a stock tire.It will also likely make your odometer and speedometer innaccurate.
While I have replaced wheels and tires on previous vehicles, I have generally done so with the same tire height and width as the one that came from the factory and the wheel with the same (over very close to the same) offset, so please forgive my general ignorance on the subject.We had pictures from Detroit. The show truck tires were Firestone Destination A/T 265/60R18s. Honda turned the raised white lettering to the inside, and you could see that the lettering was partly rubbed off. Joe said he was told by a Honda rep that was the largest tire size that would fit with the limited clearance, and even then there was some rubbing.
I'm no expert on tire swapping either, generally having not gone up more than one tire size on any truck I've owned. There are others here who have experience with these issues, but none with the G2 RL, so it's gonna take some experimenting to get those answers....If you were to replace the factory wheels with a set with a +35 offset, that would push the wheel 2cm toward the outside of the vehicle. This would likely push the wider tire outside of the fender well and presumably lessen fuel economy as a result (and some states might make you get fender flares), but it seems like it also might keep it from rubbing. It would also change the contact patch of the tire in relation to the vehicle, which could cause a slight increase in tire wear while turning. What other potential problems might I be missing and how significant would any of them be?...
This seems somewhat hypocritical on Honda's part since they debuted the truck with larger than factory recommended tires.There's a standard warning in the G2 owner's manual about mounting any tires other than the factory-recommended size.
I totally agree! And the only way for Honda to redeem itself is to give us a trim package (call it Sport-X, Adventure or something else if they're so adverse to "Off-Road") with the necessary tweaks for 265/60's and enough room for limited-clearance chains. We'd then have a respectable 8.4" of ground clearance. :act024:This seems somewhat hypocritical on Honda's part since they debuted the truck with larger than factory recommended tires.
I havnt had a problem with my lift or the truck with 1 inch taller tires stock wheels for 12 years and same as a friend but with a different lift running stock size tires, we put are lifts on VERY early he has 225,000 miles and I have 106,000. He ran with the Skyjacker, mine is Truxx, I got the links he didnt, his rear end is half inch higher, mines a level kit which was .05 shorter in rear, his was cheaper in price. Just going to a different wheel offset for a change in tire size can be just as bad as putting a lift on anything its no different then a spacer with a stock wheel. Im a firm believer that if your going to do it do it right away. All those components get worked into a comfy zone then when one changes it after several thousand miles and you get leaks, noises, shaking, worn out parts cause you changed it all up (my own opinion). That being said I dont no a thing about this new RLs suspension yet and thats why its a waiting game for me. Once I see specs from some major off road truck companys I'll make my choice to do or not to do. Back in "06" it was the same thing, so its ones choice or roll of the dice for issues maybe later on. The more years that go by the manufacturers dont want you to touch anything. They are even makin it harder for john the local mech. down the block to work on any newer models. Just my .02cents good luck and cant wait to see one lifted, if it fits my needs you will see one if it can be done.:grin:While I have replaced wheels and tires on previous vehicles, I have generally done so with the same tire height and width as the one that came from the factory and the wheel with the same (over very close to the same) offset, so please forgive my general ignorance on the subject.
That said, since we know that the factory tire is the same as the Pilot, I think that it would be reasonable to assume that the factory offset is either the same or very close to the same. Assuming that wheel-size.com is accurate, the '16 Honda Pilot has a +55 offset and based on internet calculators, the 265/60 is approximately 3/4" wider and nearly an inch taller than the factory 245/60 and the tire appears to rub slightly.
So here's my question: If you were to replace the factory wheels with a set with a +35 offset, that would push the wheel 2cm toward the outside of the vehicle. This would likely push the wider tire outside of the fender well and presumably lessen fuel economy as a result (and some states might make you get fender flares), but it seems like it also might keep it from rubbing. It would also change the contact patch of the tire in relation to the vehicle, which could cause a slight increase in tire wear while turning. What other potential problems might I be missing and how significant would any of them be?
I used the following to play with measurements:
https://www.rimsntires.com/specspro.jsp
TSW Sochi knockoffs?Here is a pic of the RTL-T with the 22 inch wheels.
There are two Michelin Premier LTX tires in that size, with the following specs, just for comparison (tires are like food, people like what they like, and spend what they want to spend):The tire and wheel company dealer uses said the size tires for the ridgeline he recommends is 255/50 on the 20 inch wheels.
