Black Plastic Panels/Trim
1741 Views 4 Replies 4 Participants Last post by  huyscm
I have scuff marks on the lower black plastic trim. What is the best way to get these out?? I have tried soap and water with no luck and I don't want to put any harsh chemicals on them. :frown:
1 - 5 of 5 Posts
On all my previous cars with that lower black plastic (the first was the 1988 Jeep Cherokee) I used Armor All on it. Usually if you do it just once in a while it keeps it looking good and hides the scrapes from use.
Steve M
Steve M
Armor All is the worst stuff you can put on anything, it's just a greasy slick products that attracts dirt and dust, worthless product. If you actually want to repair the problem with scratches in plastic as well as on your vehicles paint surface, I even use it on my motorcycle windshields to remove mars and light scratches, I would use Meguiar's #2 Professional Fine-Cat Cleaner, you must use a soft polishing rag, nothing but a soft material, no paper towels, I can't stress this enough, if your rag is rough you will just add more scratches to what you are polishing.
trainman
Reactions: 2
trainman
Thanks Trainman
Reactions: 1
Depending how bad they are Meguiars Paint Protect has worked for me.
http://www.meguiars.com/en/automotive/products/g36516-paint-protect/#8A1Ug2Ky5vSXSqTz.97
If that does not work the only other option is to replace the piece.
1 - 5 of 5 Posts
