I just have to plug the Harbor Freight bleeder that shovelhd mentions. I suspect most of us have used the "time honored" two person method with great success. The last two times I used the Harbor Freight bleeder also with great success. Have to say that I have not used it on the Ridge yet, anyone? . It takes just a little practice to squeeze the handle to get the optimum vacuum and crack the bleeder just enough to allow bleeding without sucking air back through the bleeder threads. Preaching to the choir right, but the same problem exists with the two person method, just to a lesser degree (if you don’t coordinate well with your helper, and/or you open the valve too much) since the vacuum tool can provide quite a bit of suction and more easily back pulls air through the bleeder threads.
The key to the Harbor freight bleeder seems to be don’t just squeeze the handle all the way down, but give it a little bit, while you crack the bleeder, otherwise you will get foamy output from the high suction pulling air through the bleeder valve threads. Perhaps the foam isnt such a big problem since its being evacuated if you know what I mean, but I was able to avoid it so why not and it makes it easier to visually confirm that you are getting clear bubble free fluid. Also one vehicle seemed much more prone to pulling air back through the bleeder valve than the other. Tolerance in the threads, I assume? But all in all a great tool that makes a complete flush as easy as it could be. I have looked at one of these things from time to time but stuck with the two person method because they were always $40 or $50 and didn’t have the refill reservoir. This unit isn’t just similar; it’s identical to ones I’ve seen elsewhere for twice the price.
I’ve also considered those bleeder valves with the check valve, and they also seem to have some sealant around the threads. Not sure I’ll ever invest in them, but they seem like a good idea. Anyone have them?
For my money, I pretty much only bleed about the same interval as I would do a complete flush and if you are going to do a complete flush why not make it easier on yourself by at least using a refiller at the master cylinder. Way overkill in fluid volume in terms of waste, but last time I just paid ~$7 for a quart of quality brake fluid and filled my “refiller” bottle and then used the Harbor Freight bleeder to pull most of the bottle in roughly equal amounts. Overkill in the amount of fluid you could get by with, but you don’t save partial bottles anyway, and process is so easy with this thing. The manual is available on their site if you want to check it out.
