I have the unit that is linked - BTC450. It does work, but music quality streamed with BT is only fair. It can solve the hand's free Bluetooth problem cheaply, but has wires strewn about unless you do some fancy hiding. Uses power port and requires mounting the unit somewhere on dash. I would not spend the time to try to hide the wires.I would assume that you have an aux input on your Ridgeline with Navi?
If so you can get this type of item:
http://www.amazon.com/Kinivo-BTC450...1451252261&sr=1-11&keywords=bluetooth+adapter
I have a similar Belkin version of the above. Phone stays in my pocket. You can ping Siri or Android voice recognition by pushing the button/mic. Sound quality for the phone calls is good and people can understand you fine. You can also stream music through the bluetooth. Sound quality is good and is pretty much the same as if you connected your phone directly with a mini headphone jack cable.
I went with the USA Spec BT45-HON and really like it.
Try this.....
http://www.ridgelineownersclub.com/forums/showthread.php?t=104897
What about an apple 30-pin to micro usb adaptor?
Yes, some are set up for charging only. Have to make sure it's compatible with iPhone 6 audio output. Similar to this one for the 30-pin to lightning adaptor
http://www.apple.com/shop/product/M...rid_52243316890_&cid=aos-us-kwg-pla-btb-slid-
This is the one I use for my iPhone 6. If your life case is wired to charge only, then yes, your options are to remove the case or go bluetooth
There are probably other options. Something along the lines of this?
http://www.bonanza.com/listings/New...=&goog_pla=1&gclid=COKiz-68hcoCFQ2QaQod97YL9Q
I didn't take the time to evaluate this fully. Was looking more conceptually.
Sorry but you should really read more and understand before you comment! . . . Look at the link and look at the item and understand what it is!Those cheap bluetooth devices use a FM band on your radio. They work great sometimes but usually get interrupted/static, especially in urban areas. You have to live with wires dangling about. Also, your phone does not ring over the radio. The streaming of music is mediocre at best. A good alternative is a voice activated GPS that has bluetooth if you must have an accessory device. Most phones now can be controlled by voice anyhow so the cheapest option is just a holder for your phone.
I opted for a new HU after trying a few options...happy now:act024:
Sound quality? With my Belkin you can't tell the difference between plugging in the Iphone directly into the mini jack port or streaming over Bluetooth. Reviewers for the Knivo say the same thing. With bluetooth the Phone stays in my pocket which I find a major plus. The Knivo automatically pairs when you turn on the vehicle so that alone makes it better than the Belkin that I have which you have to tap to pair.I have the unit that is linked - BTC450. It does work, but music quality streamed with BT is only fair. It can solve the hand's free Bluetooth problem cheaply, but has wires strewn about unless you do some fancy hiding. Uses power port and requires mounting the unit somewhere on dash. I would not spend the time to try to hide the wires.
My install may be different somehow, but I can clearly tell the difference between a direct cable to the AUX jack from my phone and the Bluetooth connection in the truck. I have heard it may also be an Itunes problem. Whatever it is, the direct cable is quite clearly better in the truck. I have a Bluetooth player in the house and there is virtually no difference between BT link and direct cable link. Given this limited info, I have surmised the problem is the BT unit in the truck. But I could be wrong.Sound quality? With my Belkin you can't tell the difference between plugging in the Iphone directly into the mini jack port or streaming over Bluetooth. Reviewers for the Knivo say the same thing. With bluetooth the Phone stays in my pocket which I find a major plus. The Knivo automatically pairs when you turn on the vehicle so that alone makes it better than the Belkin that I have which you have to tap to pair.
My 06 has been upgraded with aftermarket speakers. I also have dabbled in audiophile car installs in my youth. Listening to music through this type of adapter certainly isn't on the same level playing a CD from the head unit but for Itunes and Pandora it is indistinguishable.
Hide (most) of the wires if you want, or don't bother. That's up to you. Also the part that plugs into the cigarette lighter has one or sometimes two USB ports for charging so its not really completely hogging a power port. How are you ever going to have any sort of hands free setup on the Ridge without mounting a microphone somewhere???
