Since the VTM4 diff is clutch based, it can only transfer a fixed amount of torque. As long as I'm not spinning the front wheels there should be minimal extra wear to the rear diff. At least that is my thought on it.
So basically the amount of power that goes to the rear wheels is a function of how much or how little clutch slip occurs as determined by the ECU?The way I understand it, the VTM-4 diff is controlled through pulse-width modulation to the coils inside the unit. The coils squeeze clutch packs to create friction. This friction is what drives the rear tires up to 70% of the engines available torque. The 1G RL's VTM-4 design has similar clutches to an automatic transmission except it's electronic vs hydraulic. Due to a limitation of the coils capability to shed heat they cannot increase the holding power any further. This is why the new VTM-4 system is hydraulic
Now in my situation it will max out sooner, being able to transfer less of the engine's output. This means I could potentially get front wheel spin and damage the rear differential. I figure as long as I'm not an idiot I won't have any problems... At least that's what I hope for. Worst case if I do grenade the rear differential, it's much easier to replace than the transmission and they're a dime a dozen.![]()
Very good point! This is exactly why im not worried about reliability. As long as I'm not sitting spinning the tires I'm sure ill be ok!It's maybe useful to think of it slightly differently. The max torque applied to the rears has to do with traction conditions. The control system applies a certain amount of clamping force based on its calculations. If you're driving away from a stop sign, it may still clamp the clutches, but there will be no clutch slippage because there is not a traction problem at the front tires, and the driveshaft going rearward from the tranny never spins faster than the output shaft going to the front diff/wheels.
In that circumstance, Less than 100% of available torque was applied to the rear wheels, but there was no clutch slippage.
Beautiful! Looking forward to your dyno results. By chance is there a pre-swap dyno run to compare to post-swap?A couple notes If anyone does this swap. The RL injector Clips will not fit the J37 Denso injectors, they are different. All you need to do is remove the pins from your factory clips and put them into the injector clips that come on the TL engine harness. Also, use the ZDX air intake tube with a 3.5" 30-degree aluminum elbow to meet the filter housing with a 3.5" coupler. It is much cleaner trying to use as many factory parts as possible.
My list of things to complete...
1. Get correct hose clamps for ZDX intake tube
2. Paint aluminum elbow matte black
3. Replace intake mani cover with accord v6 MT part for a more factory appearance. I could use the Ridgeline intake manifold cover but it's ugly and I don't want to put the plastic back on
4. Finish street tuning
5. Take the RL to Bisimoto for the final tuning and dyno
Theres also a missing clamp at the throttle body that has since been rigged with a zip tie. I dont have anything that will fit and there is an indexing rib in the way on the intake tube. FYI my OCD is costing me almost $20 for 2 hose clamps haha! Waiting (im)patiently for parts to deliver to tie this thing up. Took it out on the freeway and man this thing is epic. It no longer hunts around on the smallest of hills. It no longer feels underpowered like it did at low RPM. The low end is great and the high end is totally honda!!!Beautiful! Looking forward to your dyno results. By chance is there a pre-swap dyno run to compare to post-swap?
Also, I'm damned happy to hear you're going with correct hose clamps on the intake tube. Everything is soooo damned purdy, my OCD was shorting out over the orientation of the clamp head closest to the throttle body. :nerd:
Dopes,
Very interesting swap! Makes a lot more sense to me to give the Ridge the low end grunt that it needs rather than mods that give it more power at high RPMs where I am almost never spending any time. . .
Can you give some more details?
Year and model range of Acura donor vehicle?
What parts other than the engine need to come along?
How much $ do you expect to pay on the tuner end of the project?
Please keep the updates coming. Very interested in performance as well as things like gas mileage etc.
Thanks!
