Yes all of the ridgeline wiring is intact. The only thing disturbed were the fuel injector clips which you pop the little center piece out with a small flat head then you can lift the tiny tabs and slide the pins right out and into the TL connectors. The process takes less than 10 minutes.Thanks for the additional info!
To be clear . . .All the wiring harnesses are Ridgeline?
