The center bore is 64.1mm with the register being 70.1mm. This is on the vehicle hub side.5x120mm
72.5mm hub (wheels are hub centric)
M14 x 1.5 nuts
Ah shyte.... my bad I was looking at my hub centering ring measurements, 72.5mm x 63.8mm. So the OEM hub is 64mm Thanks for noticing that.The center bore is 64.1mm with the register being 70.1mm. This is on the vehicle hub side.
Not sure what the 72.5mm hub is.
Also the Lug diameter should be a minimum of 14.4mm.
