Very nice. Do you have any more photos from different angles, especially from the front?I have a similar setup with Wildpeaks, 2"/1" lift and 1" Bora spacers.![]()
Throwing my two cents in - I orders 1 inch spacers all around from Bora. I have a 2019 RTL-E with OEM wheel and tires.
The stance is nicer - subtle but looks less "front wheel drive minivan" and more like I want it to. Pictures don't really do it justice - I didn't take many before/after as they're hard to differentiate I think. Below is one from the back - where the slightly wider stance is visible. Another one down the side - that one tougher to tell unless in person and then you notice it, but you're not sure what you are noticing. Subtle but seen.
No issues with rubbing or fit but I am stock - height, wheels and tires - all stock.
One last thing, on the Select Centricity page, it has two options (which one am I to choose)Yes - use what they propose. Here’s the copy/paste from my order info.
Honda Ridgeline (2006-2019) Spacers, 5x120 Bolt Pattern, 64.1 Hub. Aluminum, BORA Black, Thickness=1in (25.4mm)
Sent from my iPad using Tapatalk
Nevermind, I was using the custom configurator; I see the Honda one now. sorryOne last thing, on the Select Centricity page, it has two options (which one am I to choose)
1, Hub Centric to vehicle hub (this is a flat spacer that fits perfectly tight on the hub.
OR
2. Hub centric to vehicle and wheel centric to wheel (Fits hub perfectly tight and, where wheel bolts to adapter, a custom machined adapter lip fits perfectly tight into wheel's center hole. This extra measure positively influences the ride and kills vibration. Highly recommended for newer vehicles and those which will be used for towing)
2 is the default, if that means anything
Can someone give the website for these Spacers?
[/https://www.motorsport-tech.com/
None yet and I don’t expect them to have any discernible effect.Those of you that have added 1 inch or 1.5 inch spacers, have you had any problems with your wheel bearings or other suspension components. 1 inch would be good enough for me but just wondering if they cause any problems. I've never added wheel spacers to a vehicle before and just wonder whether they would have negative effects.
Thanks for the feedback. I have never really liked how the truck looks with tires tucked in the way they are.None yet and I don’t expect them to have any discernible effect.
20 available of what exactly?Received my Bora spacers tonight. Very happy with the quality of them, and they came with the open ended lugnuts (so now I have 20 extra if anyone needs them). I think the .25 difference between front and rear makes them appear about even. Very satisfied with the purchase.
Before
After
Before
After
Website? I see motor tech-sport has them but it doesn’t say if they come with lug nuts or not.I have 1 inch all around. Would buy the same again.
How many miles on the truck since you have installed the spacer?None yet and I don’t expect them to have any discernible effect.
Mine came with lug nuts.Website? I see motor tech-sport has them but it doesn’t say if they come with lug nuts or not.
~7500How many miles on the truck since you have installed the spacer?
How long did it take you to do the install yourself? is really that easy to just take off wheel, slap on the spacer and reapply the wheel with the shorter lug nuts?BORA 1.5in wheel spacers installed on a 18' RL Sport AWD with a 1.5in TRUXXX leveling kit (front only), Falken 265/R60R18 Wildpeak All-Terrain tires on the Ridgeline Sport Factory wheels (18x8.0 55mm offset)
The lug nuts are open end, ball seat, with a 14x1.5 thread pitch. This is a must since I was using the Honda factory wheels. I had a hard time finding these types of lug nuts locally so I purchased them online. Seems like Porsche and Honda share the same ball seat type lug nuts for their factory wheels. Any other type (conical, cone, etc) will not work! You need the ball seat type to secure the factory Honda wheels to the hub.
The Ridgeline handles a lot better with the wider stance. Some rubbing when turning left fully lock. The tires poke out about an 1in upfront and maybe 1.5in in the back. Stance looks great without trying to hard. I wouldn't go any wider than 1.5in with the wheel spacers tho. The spacers are hubcentric, high quailty, made in the US, and life time warranty. BORA engraves your invoice number on each of the wheel spacers. It takes approx 7 to 10 business days for them to manufacture your spacers and additional 2 to 3 days to anodize it. It took about 3 weeks to get the wheels spacers made and shipped to me. So plan ahead! I wanted to keep the factory wheels since I like the gun-metal gray look on the Lunar Silver RL. Just upgraded the tires to the Falken Wildpeaks.
The Ridgeline looks a lot more beefier with the stance and wider tires. Handles A LOT better with less roll!
