I can't imagine what "between 0*-70*" could mean. Are you asking about mounting it directly under the steering wheel? If so, I would definitely advise against that. Not only would you be creating a sure knee knocker, you also need to be able to view the display or knobs occasionally while you set the drag, or whatever the approrpiate braking pressure is called.shingles said:The prodigy controller says it has to be mounted between 0*-70*. Does that panel under the steering wheel work ok?
The panel is less than 70 degrees, so it will work fine.The prodigy controller says it has to be mounted between 0*-70*. Does that panel under the steering wheel work ok?
