Man I have searched everywhere on this forum for insight into this super annoying problem I am having with my brakes. If I can get some help resolving this, I will seriously send you $20 tip through Paypal.
Vehicle - 2007 RTL
Initial Problem
Master Cylinder started failing - would not hold brake pressure and while driving I would have to hit the brakes early and maintain pressure or the pedal would go to the floor with little to no stopping power (or I would have to "pump" the brakes to stop quicker). The truck would lean to the front left when coming to a complete stop which indicated to me that pressure was being lost at the brakes further away from the master cylinder.
My Fix
Replaced the Master Cylinder
Replaced the Front Brake Calipers (one seemed like the piston was getting stuck and the dust cover was torn up)
Replaced Front Pads
Replaced Front Flex Lines with Stainless Steel lines (thread here said bad line can act like check valve)
I did not bench bleed because the guys helping me said it wasn't a big deal because we were bleeding the whole system anyways.
Made sure everything was thoroughly lubed with disc brake lube.
Bled lines at all 4 wheels w/ 2 person method (twice)
which leads me to the CURRENT ISSUE
The front brakes rub a ton and then seize up completely after driving a short distance.
I am curious if anyone has some knowledge that could help aim me in the right direction.
Vehicle - 2007 RTL
Initial Problem
My Fix
Replaced Front Pads
