While I consider that excessive consumption, Honda will likely tell you that is normal. That is a quandary.
When the truck was brand new with less than 100km on it, the oil was not at the full mark?I am a little concerned about this oil level…... I checked when I bought it three months ago it was just above the middle level now its almost at the end.
I was questioning this as well.When the truck was brand new with less than 100km on it, the oil was not at the full mark?
Àll driving is city never driven over 3000 rpm for first 2000 and very few hard accelerations after that just to get into the lane. Always in eco modeWhen the truck was brand new with less than 100km on it, the oil was not at the full mark?I am a little concerned about this oil level?... I checked when I bought it three months ago it was just above the middle level now its almost at the end.
It is not unusual for a new motor to consume some oil. Check it more frequently than once every 3 months. Consumption should lessen over time and distance.
What was your break-in procedure?
Your dealer does oil changes using your oil and filter?!?I will always be taking my own oil & Filter to the Dealership for my RL. Mobil 1 synthetic extended performance and Mobil one extended performance filter. It helped in my very hard driven 09 3.7 acura TL. If driven hard it used to drop half a quart after 4000 kms
You may want to run that puppy like you stole it. Especially since you've got it broken in. Let them rings and valves seat in. The whole thing may turn to sludge:surprise: if you never get over 3000 rpms, especially with cms. It's a truck/tool not an infant.Àll driving is city never driven over 3000 rpm for first 2000 and very few hard accelerations after that just to get into the lane. Always in eco mode
I found it hard to baby mine when I first got it - after many years in a 4-cylinder wagon, the RL's acceleration is hard to resist! It's not a sports car, but feels like one in comparison.Ridge17's comments may sound like slang but they are fact!
It is ill advised to baby a new vehicle like that. Don't be afraid to bring the revs up and drive it.
Tis true, I wasn't making a flippant, uneducated comment....although it may have come off that way. There have been many discussions about this, especially in the motorcycle, outboard motor forums. The end result of excessive idling and low rpm usage during break in is increased oil consumption and many times in the case of outboards, fuel contamination in the oil. The old rules don't always apply in this age of CAD/CAM.Ridge17's comments may sound like slang but they are fact!
If the truck is babied, the rings will never fully conform to the cylinders and it will burn oil it's whole life. It will also build less compression and be slower. The xx% of ring contact will achieve full polish, ring expansion is halted, and xx% of the rings will NEVER reach the cylinder walls. In short, driving it hard raises the ring pressure and allows proper break in.
Do a google search, motoman break in. My S2000 with 3 miles on it was broken in the same way. At 150k miles the car is a rocket and uses no oil under normal driving. I also break in every S2000 engine I build the same way. And my new RL.
Test drive two vehicles, one babied and one broken in strong. You will CLEARLY notice the babied vehicle. Perhaps a Ridgeline meetup to compare trucks ��
