First off, thanks for all the information I've read on here. It's been a great value to me. I've gotten a lot of information from DIYMA as well.
I've taken awhile to assemble all my gear, but I finally have the major pieces. I have the following already purchased:
Pioneer 4000NEX installed
PPI 900.5 amp
JL 10TW3-D4
Silver Flute 6.5" mid speakers going in stock locations
JL C5-75ct tweeters going in stock locations
I'm going to run the fronts active and probably disconnect the rear speakers. I'm building the sub box based on the ED-10 build that's popular on here. I'm going to mount the amp on the wall on the drivers side. I also have a large box of sound deadening material I got a good deal on & will do probably 50-75% coverage on the front and rear doors.
I'm going to run 4 gauge power & ground. I'm checking to see what cable lengths anyone used and if you thought it was too much or not enough. I know I can measure, but you can never account for any headaches along the way. Any tips? I wanted to do the tweeters in the sails, but after reading how much of a nightmare it was to run the wire through the driver door, I don't know if I want to try to run 2 wires in there. Also what gauge wire did you use when running the wire through the door? Is the molex plug the hardest part of the install? That seems to me it is.
PPI 900.5 amp
JL 10TW3-D4
