1 - 13 of 13 Posts
im sure this is a common problem with older vehicles. what say the hive on the best way to fix? ive seen "cover" on ebay which look cheap. i can remove and recover myself if i had an exact color match. its a very light tan.
NOT a common problem..... I can only suggest ^^^^^^ what STUV said... unless you want to spend hours calling salvage yards trying to find another used one. I wouldn't worry that you would suffer the same problem again.... I've never seen or heard of that kind of separation. Looks like some kind of oil (or other chemical) was left on it for a while.
If you're going to ditch it anyway.... you "could" try hitting it with a hot hair dryer or gently with a heat gun to see if you can get any shrinkage that might pull it tight again??? Totally trial & error that could make it worse.... but if you're going to get it fixed, you've got nothing to lose with an experiment like that.
Good Luck!
· Administrator
Whoa. That's...unsightly. Never seen that before! The front corner of the "leather" (vinyl) armrest in my 2010 started getting sticky after a few years where my lotioned-up elbow rested. I bought a new console lid and replaced it which was cheaper, faster, and easier than having it re-covered.
Had same thing happen on my 09, though only 2 spots the size of quarters. Replaced the factory fake leather with a real leather replacement a guy sold on ebay. It was gray and very close in color. Think it was like $35 bucks but you have to install. Wasn't too hard and came out looking like factory. Over the year or two that I had it, the leather has matched the car leather more as it worn in and gotten dirty like everything else. So far still looks great and would recommend if your handy at fixing things to make it look good.
^^^^^^^^^^^ WHAT HE SAID !
($79. + shipping @ bernardiparts.com)
Discussion Starter · #7 ·
i first ordered a replacement piece of leather that i would have had to install myself. the seller said it would be "a good match" to my beige interior. well it wasnt. no where close.
so i returned it and just bought a factory replacement sliding lid from Honda. took 3 hands to get the old one off but it matches perfectly.
How do you remove the center arm rest and get at the cover..?
How do you slide the center console lid off?
407327
407328
407329
407330
407331
I just replaced my center arm rest cover that I bought on eBay in 2017, LOL. See pics, I followed a shortcut to get armrest off. Looking at pic, lift up armrest, slide forward and take two strong flat heads and place near area with yellow circles. Push up on plastic, as the metal stoppers will not move. With a second set of hands, have them slide off as you apply pressure on screwdrivers to separate the edges of plastic from metal.
Once you slide off, unscrew the four outer screws (I did them all, but don’t think you need to) and pull apart the two pieces. Remove the old “leather” and align the new one in place (this is probably the hardest part). I used pieces of gorilla tape to hold the new cover where I wanted to get plastic piece back in place. Many adjustments will be needed, at least for me it did.
Now, my cover also slid freely without much pressure, so I removed the two pieces in the blue rectangle, pulled the springs out to make them tighter and put them back in. The cover doesn’t slide freely anymore and now slide when I want it to.
View attachment 407327 View attachment 407328 View attachment 407329 View attachment 407330 View attachment 407331 I just replaced my center arm rest cover that I bought on eBay in 2017, LOL. See pics, I followed a shortcut to get armrest off. Looking at pic, lift up armrest, slide forward and take two strong flat heads and place near area with yellow circles. Push up on plastic, as the metal stoppers will not move. With a second set of hands, have them slide off as you apply pressure on screwdrivers to separate the edges of plastic from metal.
Looks good ! Appreciate the pics . I’ve have been putting this off for the longest time ... As for the reinstall of the new piece , how difficult was this and did it just need to be glued down etc? Thanks
1 - 13 of 13 Posts
