1 - 20 of 20 Posts
Did a search on this but no luck. Can the battery in a camper be charged while towing through the 7 pin connector. Apparently there is a power lead but will it carry enough amperage to charge a battery?
Thanks in advance for your help.
Charging doesn't require a lot of power/amps. the power in the 7 pin is meant to supply a low current charge. anytime you have a greater potential/voltage applied to a battery than the actual battery voltage it will absorb that potential and charge. I recommend that you use a shop charger on your trailer battery if it is dead. The truck circuit won't carry enough amperage to effectively recharge a dead battery.
Discussion Starter · #5 ·
I do have a shore power converter charger in my teardrop and will also have one in a new camper I am building. I am considering using a 12 DC / 110 AC coolerator refrigerator in the new camper. My thought is using the feed from the RL to run the cooler and possibly charge the battery while traveling. Once reaching the campground we will plug into 110 if it is available. Most National Parks don't have electric hook ups and charging while traveling would be helpful.
Thanks for your help. Hopefully the dealer installed wiring harness and circuitry protects the RL from any potential feedback issues from the trailer battery.
· Super Moderator
The only thing you may want to consider is an isolation circuit breaker. I'll find one and add it to this post later. We installed one on my dad's trailer so he could stay connected to His Honda Pilot and not disconnect anything when over nighting on his 7800 mile cross country trip last year
http://alturl.com/dozr7
Interesting question...(can you charge the truck from the trailer electrics).
I haven't been able to find an answer to that. Lots of questions about the other way round, and lots of additional information.
Essentially, the truck charging line is too small to put more than roughly maintenance charging...it can't support enough amps to charge a deeply discharged marine battery.
Also...for the fridge (aka reefer)...try not to run it off 12V...it draws a LOT of power. LP or 120 is the way to go...and would explain why the 3-way fridges are fairly hard to find.
Can a two-way RV fridge be operated on propane without assistance from the RV battery?
All the ones I had you could. I suppose if someone put the igniter on the 12v system, it wouldn't, but I can't imagine a mfg doing that (I only mention because anything's possible). My older ones had a pilot light, and my 'newer' ones had battery (2Ds) to power glow plug igniter.
Discussion Starter · #13 ·
I've completed my camper and have the 12V output from the Ridge connected to the Fridge and battery circuit. It is a Dometic refrigerator that will automatically switch to 110 when shore power is available.
Some have talked about an isolation device but isn't the 12V source disconnected when the key is off? I am not too worried about it as I unhook the trailer when I set up camp.
Discussion Starter · #14 ·
Another pic of camper. It is 6 X 12 feet long and 81" high so it will fit Through a standard garage door. Inside is 63" with the drop floor, has a dinette for two and a 60" X 71" almost queen size bed. Galley is in the rear. I haven't had it weighed yet but expect it to be less than 2,000 lbs.
Nice. 12v feed line depends on the real source. I haven't checked mine for if the 12v feed is constant or not. I have trailered for multiple days without unhooking, but with ac every night I wouldn't have noticed any battery drain.
Do you have a propane setup, or is it all electric? I've read that 12v for fridge didn't have enough power to cool things, but can maintain cool.
Do you find this portable 'fridge' works well? My wife wants us to consider one for long road trips. I've never heard any first-hand comments. How's it work for you?
Discussion Starter · #17 · (Edited)
I have only used the fridge once but it seemed to work fine. The Dometic claims it will freeze down to zero but I had it set just for refrigeration. I ran it off 110 at home before I left and it was cold. It stayed cold while traveling about four hours then when at the campground it was back on AC. Worked well all weekend keeping things cold. No more food swimming in melted ice water. I still use a cooler and ice to keep the beer cold.
The Dometic is not your average 12V cooler. The one I have sells new for $600.+. Fortunately I bought mine for less from a friend. Most other powered coolers will only chill to 30 degrees below ambient temperature which is fine if the outside temperature is 70. Others also cost much less. Do your research before purchasing one to make sure it will meet your needs.
Discussion Starter · #18 · (Edited)
On the RL the 12V line is only hot when the ignition is on. I would not expect any reverse feed when off. If I am incorrect with this logic someone please correct me.
Although not with this setup I have also camped without unhooking when just stoping for an overnight while traveling. If necessary it would be simple enough to unplug for the night while staying hitched to the RL. I can see me forgetting to reconnect when I get up in the morning.
I have propane but only for the two burner stove. I did run the Dometic on 12v only and it cooled quite well from 80 degrees. See above post for comments about the fridge. Truckers seem to use them quite a bit running on 12V only.
Ah, gotcha. I didn't notice that it was a special cooler, rather than the typical rv refrigerator. I run my fridge off propane when I don't have access to AC.
I concur with your assessment on back feeding 12v to the truck. (At times that would be a handy feature).
1 - 20 of 20 Posts
