We have a few RL's, all with less than 10,000 on the odometer (yes, not a typo) and almost at random the Check VSA system illuminates the diagnostic panel (all are RTL/Navi so the Icon shows plus the actual text on the panel)
Now, button for VSA ON/OFF toggle works fine at startup, when left in normal/default ON mode, warning message does not immediately display at start and at least on one of the RLs, at one point when engine was started at fillup, no warning showed up until it was parked, it sat for an hour and then after pulling out it shows up again.
No other indicator shows up.
All of them have proper fluid levels (brake, transmission, engine, differential, VTM).
All have correct tire pressures.
None have any recent maintenance done (within last 2 months) apart from annual engine oil/filter.
All have a new AGM battery, verified, voltage shows fully charged.
1. Is the ABS&VSA system a single module? (if yes, anyone with a part #/diagram for location)
2. Can the ABS and/or VSA harness/plugin become intermittently loose? (if yes, user serviceable?)
Anything else?
Anything else?
