Yep, we are still using, er -- should I say -- the dogs are still using -- our doggie deck. It's served our family well. I'm glad to have the positive feedback on it. Thanks!
I have a 1/2 mile gravel driveway that I travel on at least twice daily so I've been replacing my cabin air filter every 7,500 miles with a NAPA ProSelect (part # SFI 224815). It costs $10.49 and it drops right in.
I've got it all done, except putting the grooved gizmo back in, already cleaned the blood off the cloth seat where i had cut my hand, My hands require XXL gloves, so this might be an impediment. Guess i will head back out to the garage and give it another twirl.
JimmyG
Thanks for the info, this 06 I have is the newest vehicle I've ever owned and I want to take good care of it, don't have my Haynes or Chiltons yet and this gave me a great workaround till I do. Started off looking for the source of a musty smell after heavy rains (A and C post leak or clogged AC drain tube or plugged drains at front mud flaps possibly- I will know more tomorrow...) but learned that this is a good item to check too, ROC- THANK YOU!
Learn something new every day if you are lucky!
It turns out I'm glad to have this thread to refer to for myself. I remembered the easy process, but when the little piston arm was missing, this gave me a perfect way to show BIGGUY what is supposed to be there.
We only had an empty cannister swinging on the right side. We couldn't see the missing part in the cavity below the glove box, but it was located by reaching down and feeling for it. There was a good snap when it was pushed back into place and we finished the filter change with only that small hiccup.
I took a couple of photos from a different angle to spotlight what the arm part looks like, in the event that anyone else has the same missing part surprise. I also got a close up of the snapped down position on the post on the back right side of the glove box before the rubber bumper was put back into place.
I'm glad you found it too. Some of these old threads are still of value but they get buried. It's good to get them back to the surface for new owners to use.
Lot of folks pop the piston, you find out pretty quickly what happened. One look in the SM if you have one, if very helpful. But this is something most of us shade tree mechanics can get through without much help.
Truckin, just wanted to say thanks again for this thread. Did all of it on memory, til I got to the reconnecting the arm. I had taken a microfiber towel and wiped everything down, but didn't realize I'd pushed the arm in so here again the ROC & it's members come thru
I've gotten to the point where I could probably do this in the dark with my eyes closed by feel alone. It's unbelievably simple to do. I would be extremely mad if a dealership or other place tried to charge me $90 for this. Even taking the part cost into mind, they're charging you a dollar per SECOND.
Thanks for that bump Truckin, I clean mine every 3 months and replace when needed after that. You have saved me some bucks in over ten years. Glad your still roamin around. Do you have an open mind and waitin for the new RL or drivin that old one to the ground if you still have it.
Hey, yeah I'm still out here and I lurk a bit. BIGGUY still drives old BLUE, but hardly into the ground. She's got a few dings but is as sound as ever. :cheerleader: It's, hands down, our best vehicle purchase ever.
I just replaced these on my 2006. Here are some tips to help you do the same:
Removal:
0. Get two floor jacks. 3 works even better
1. Jack up both sides of front at same time. Remove wheels and disconnect end link (sway bar to strut connector) at the top connection. (Allen key and 17mm...
NOTE: This applies to ALL G1 model years (’06-’14)
DISCLAIMER: Customizing and modifying a vehicle is done at your own expense. The process below is to be taken as a recommended means and not an official instructions. I am not responsible or liable for the result of your work as you assume all...
I love living in the State of AZ, especially as a gun enthusiast. That being said, I was looking for some ideas on ways to mount a proper holster for easy access in the Ridgeline. There was a post going some time ago but I didn't like any of the methods I saw. My Toyota Camry I traded...
Following the receipt of my OEM fog lights, I started looking around at potential replacements since some have reported their glass lens breaking. I may have found a solution if you fall into this category. The glass says "Stanley P4988 (followed by either a "L" or "R").
Upon doing a search...
