As he said, you can reduce that effect and make it easier to move the shift lever by setting brake very solid first, before putting it in Park, when there is minimal car movement.If you are parked on a incline of some sort or put the ebrake on after you put it in park then yes it will.
Yes I have....Anyone have any issues with clunking when putting into drive or reverse?
And this is the appropriate solution...If you are parked on a incline of some sort or put the ebrake on after you put it in park then yes it will.
