Status
Not open for further replies.
1 - 6 of 6 Posts
I have a strange clunk coming from the right rear wheel on my '09 RTS when I roll over a small bump or back out of my driveway. I have been to the dealer who spent considerable time trying to find the source of the clunk without success. I had suspected a defective shock or a loose link attachment but haven't found the noise source yet.
Has any one else experienced this problem?
Had the same problem in my 08. Turned out to be a bad rear strut, my Honda dealer covered it under warr. Seems to be a common problem, they knew right away and did not give me any trouble, even though I have 75k.
Hope this helps!
:act043:
If nothing looks broken from a visual inspection, the strut is likely at fault. It may have failed internally, although you can't always tell by lookig at it. You take off the wheel and get a good look at everything?
Could be the strut. But also look for a broken sway bar link.
Chip H.
This is not a Recall, TSB or Notice
closed
There are no struts in the the rear, the "Struts" are shock absorbers. You may have a bad shock absorber or a broken sway bar link.
If neither, try removing all loose items from the trunk and cab and see if the noise continues.
1 - 6 of 6 Posts
Status
