1 - 11 of 11 Posts
I copied this from a post by rollinhonda:
VTM-4 fluid: 08200-9003
DW-1: 08200-9008A (08200-9008)
(the A designates Acura fluid)
Coolant: OL999-9011
Power steering: 08206-9002
Brake fluid: 08798-9008
Engine air filter:
2006-2008 17220-RJE-A00
2009-2013 17220-RJE-A10
Cabin air filter: 80292-SHJ-A41
Front brake pads:
2006-2011 45022-SJC-A01
2012-2013 45022-SJP-A00
Rear brake pads:
2006-2013 43022-TK4-A00
(sources: Bernardiparts.com and hondapartsdeals.com)
Crush Washers And Torque Values
Engine oil drain plug washer - 94109-14000 (14mm), 29 ft-lbs torque
FSM 8-6
Transmission drain plug washer - 90471-PX4-000 (18mm), 36 ft-lbs torque
Transmission fill plug washer - 90441-PK4-000 (24mm), 33 ft-lbs torque
FSM 14-210
Transfer Unit drain plug washer - 94109-20000 (20mm), 33 ft-lbs torque
Transfer Unit fill plug washer - 94109-20000 (20mm), 33 ft-lbs torque
FSM 14-211
Rear Diff drain plug washer - 90471-PX4-000 (18mm), 35 ft-lbs torque
Rear Diff fill plug washer - 94109-20000 (20mm), 35 ft-lbs torque
FSM 15-47
Wheel lug nuts: 94 ft-lbs torque
FSM 18-8
I think the spark plugs would be nice to have, I know they are different for newer models, having both will help.
Here's some non-OEM common maintenance items:
Cabin Air Filter,
NAPA: FIL4815
Fram: FFCF 10134
WIX: 24815
Oil filter
NAPA: FIL 7356
Purolator: PL14610/PSL14610 (synth.)
WIX: 57356
Mobil 1: M1-110
Air Filter
NAPA: FIL 9119
Purolator: A25656
WIX: 49119
Spark Plugs
NGK (iridium):
IZFR5K11 2006-2008
ILZKR7B11 2009-2011
The fluid will be same, only the label will be different, but make sure the 'root' number is the same between H and A.
Light bulb p/n's as posted by ridgeline2006 (Tony).
Here is the List of Light
2006/07/08 HONDA Ridgeline
Sylvania.com website - All automotive lights (link)
Sylvania.com website - Application Guide (link)
High & low beam headlamp
9003/HB2
9003SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9003ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9003XV XtraVision Halogen - The Brighter Light
9003CB Cool Blue Halogen - The Whiter Light
Parking light
3457ALL
3457AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
3457ALL
Rear turn signal
7440
Tail light
7443
Stop light
7443
High mount stop light
168
License plate
168
Back up light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear sidemarker
168
Map light
DE3175
Dome light
904
Step/Courtesy light
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Trunk/Cargo area
168
Thanks D, for posting the spark plugs part numbers, this Sticky was a good idea Speed. :act035:
Engine air filter:
Air Filter
NAPA: FIL 9119
Purolator: A25656
WIX: 49119
Why the different Air Filters for OEM but not aftermarket at 2009 split? I am pretty sure that 2009 introduced a MAF, did they also change the air filter material that the aftermarkets dont care about?
Its time for a new filter in my '09 and trying to determine OEM or aftermarket........
1 - 11 of 11 Posts
