1 - 7 of 7 Posts
Hello, I am new here and looking for any help regarding the issue I am having.
I have a 2006 honda ridgeline RTL. Before starting work on it I verified it started up as normal. It hasn't been driveable for several weeks due to massive ps leaks and a cracked pump (deep freeze got it).
Friend and myself took on the project yesterday and replaced the serp belt, ps reservoir, ps pump, and ps high pressure hose (major pain). We got things hooked back up and before bolting the two hose bracket isolators to the frame since it's so time consuming, we decided to atleast check things were working and not leaking. Went to turn on and it cranks but does not turn over.
Any ideas/help would be greatly appreciated.
I'm not very clear on what you mean when you say it 'cranks' but does not turn over. What does that mean?
Like when turning the key to start the car, it makes the coughing noise like it's attempting to start but never actually starts/begins running
2021 Radiant Red RTL
I would certainly start with the simple stuff first - is every connector plugged back in that you may have disconnected? Or something to do with the sparkplug coils, if you touched them at all.
The simple replacement of the serpentine should not cause a no start issue.
Discussion Starter · #5 ·
We didn't need to touch any of that stuff which is why I am so confused. I don't see anything disconnected, and we triple checked the belt and everything. To get the hose replaced we had to lay Completely on top of the block and reach all of the way towards the back bottom where the rack is on the driver's side. It is possible we could have knocked something loose but I am not entirely sure what items impact starting the vehicle.
Sorta/kinda sounds electrical/spark possibly.
Have you checked the starter cut relay?
411292
Motor vehicle Font Naval architecture Auto part Engineering
So it spins but won't light off. Gotcha.
411293
411294
Font Material property Parallel Number Document Font Parallel Paper Book Document
1 - 7 of 7 Posts
