1 - 4 of 4 Posts
Hi
Got the cross bars for a 2017 ridgeline. The installation instructions are not clear. How do I remove the rear plastic trim to slide in the bars after removing the torx screw. Does the whole rear trim come off or just a part. I am scared to use a screw driver in caseI break something!
Advice needed
Thanks
Welcome to the ROC & congratulations on your new RL!
The instructions show the trim comes off using a plastic trim tool available thru Honda - Plastic Trim Tool (T/N SILTRIMTL10). It looks like the cover is several inches long. College Hills Honda sells the tool for under $10. Some folks are probably fine with trying a screwdriver but I'm the cautious type. If I was doing the job on my truck I'd buy the tool. You can get a better look at the roof rail instructions at the link below.
http://techinfo.honda.com/********/pubs/AI/AH/AII02857-19/enu/AII02857-19.pdf
Good luck - hope you enjoy the new ride!
Thanks for the info. Link to Honda requires I pay them for access - bummer.
Any free links to info? I will get the tool as suggested.
Happy holidays :smile:
1 - 4 of 4 Posts
