1 - 6 of 6 Posts
My 6 week old RTL-E cruise control icon is no longer showing when prompted and instead a text box is in it's place which just says "Cruise Mode". When first purchased, it showed a vehicle icon and the distance indicator along with the speed the cruise control was set at. Has anyone else had this issue or am I missing something? Newbie says thanks.
2020 Ridgeline RTL-E
Any chance you hit the “Menu” button on the right side of the steering wheel? It’s the button above the “+” button.. that turns off all the sensors, so Adaptive Cruise Control “ACC” will not activate...
Sent from my iPad using Tapatalk
Hold the distance button to toggle between ACC and CC.
It's explained in the Owner's Manual.
Thanks zroger73, I knew someone here would be able to help. I'll give it a shot and also check out the manual which I should have done in the first place. You guys are a great help and resource for anyone owning a Ridgeline.
2020 RTL-E Deep Scarlet Pearl
I find it odd that when it is in ACC mode you have a visual of the speed setpoint, but when in CC mode there is no indication of the speed setpoint. Why not have a visual setpoint in CC mode?
I can't think of a good reason, either. Most other brands DO show the set speed regardless of the cruise control mode.
1 - 6 of 6 Posts
