I agree. Even the Gen 1 cup holders were better (after they fixed them with the updated parts).
They do look nice. I have a set, they make the interior look finished."CupHolderHero is like a floormat for your cupholders, resulting in a fresh, clean car that makes you love driving."
That's promising a lot for a set of auto cubby pads!
They came with some double sided tape which I used on the rear cup holders so they wouldn’t fall out when the armrest is stored. That tape could be used instead on the forward cup holders to keep them from sticking to the cup and coming out when the cup is picked up.I also own the CupHolderHero "floormats" and like them a lot. However, do not put them in the second row center armrest cupholders, because they raise up the cup just enough that it will wobble in the holder and might tip over (personal experience). They also have a tendency to stick to the bottom of some cups and will fall on the floor when you remove the cup.
I do like them and they do dress up the interior a little, depending upon which color you get. No, I have not found anything for the sliding center console.
I used the tape also, but I was mainly referring to the raised height of the cup inside those second row center cup holder. The cup holder is not deep enough to hold anything securely but a small sized cup.They came with some double sided tape which I used on the rear cup holders so they wouldn’t fall out when the armrest is stored. That tape could be used instead on the forward cup holders to keep them from sticking to the cup and coming out when the cup is picked up.
