1 - 6 of 6 Posts
· Premium Member
Dash LEDs
Using resources here on the ROC I finally got around to LED back lighting for dash switches, etc.
There's nothing much to add to what others have discussed here, but there was a particular issue with the HVAC control center seems worthy of mentioning.
First, removing the control module from the dash panel is the only way to facilitate installing polarity conscience LEDs. Once the module is freed from the dash panel, getting the LEDs properly oriented in their sockets is fairly easy.
Second, the T4 designs I’ve seen – which is fairly limited – all seem to be constructed the same way: “chip” LEDs (probably) SMT placed on the emitter side with solder pads on the fixture side. Of the few I’ve inspected closely, the circuit wafer is NOT physically attached to the T4 housing. This construction technique relegates soldered joints and lead wires to perform both electrical and mechanical duties - holding the populated wafer in place. While not uncommon, that is certainly not a preferred assembly technique – BUT – we are talking about pretty cheap parts here, so as cost of assembly technique, this is understandable.
The reason this is important to know is: the wafer spins off the fixture very easily. Even when being very cautious.
Emitter side of the wafer:
Yellow
Fixture side:
Circle
The fixture itself:
Circle Auto part
After popping the head off two, I decided the opening on the HVAC circuit card was a tad to narrow to accommodate dropping the wafers on these particular T4's into the opening, so out comes the mini rat tail file.
Electronics Technology Electronic component Electronic device Electrical network
A couple of light passes created a smooth drop in opening. With all T4’s in place and properly oriented, the dash went back together.
About an hour after reassembly, I notice the fan speed control switches were not illuminating. Crud. It’ll hafta wait til next time the dash comes off. And so it did this last weekend.
Here’s what I found:
Light Automotive lighting Headlamp Lighting Incandescent light bulb
Door handle Photography Metal Bicycle part Macro photography
As you can see, the + & - leads came in contact with each other. Seems as though this should have popped the supply fuse, but it didn't. The resistor burned until it opened completely. I'm pretty sure this happened as I was working to find the right balance of filing just enough and experimenting with fit. Even with care placing and removing the fixture into the opening, the wafer ended up getting twisted - it was VERY easy to spin these things in the housing. So whatever you do, be careful!
If you find yourself with this issue, a few more notes that might prove helpful: I clamped the shop vac hose close by while filing just to keep debris from dropping into the opposite side of the circuit card. And, although there's plenty of room for this kind of work, be mindful of depth when passing the file into/out of the opening.
· Premium Member
Thanks for sharing. I have three lights out on my 07 and am going to replace them..the temp control knob, the 4 way flasher, and the cruise switch. The leds I got to replace them are a single smd and I'm hoping they fit without modding the housing. Also hoping a single smd is at least as bright as the stock type incandescent ones..dont need them brighter but at least as bright as stock. Am going to replace all the T3's and T4's while trim panel is out. Hoping to get it done soon.
I thought about LED's when my dash and radio lights started burning out about a year ago. Instead of worrying about polarity of the LED's, I went to a radio shack going out of business and bought the smallest grain of wheat bulbs they had and replaced all of the OEM bulbs with the radio shack ones. Since they are incandescent there is no need to worry about polarity. Just twist out the old bulbs, remove them from the plastic mount, insert the new bulbs and bend the leads over, then twist the plastic mount back into the dash.
The grain of wheat's were 2 for .99 and I was even able to put the colored caps on them just like the OEM's.
LED's are good and last longer, but they are noisy in the radio frequency spectrum and would interfere with the amateur radio equipment I have mounted in the truck.
Do you have a link to the recommended LED's to order for the various switches and areas?
Did you ever get a reply?
Thanks,
Duane
1 - 6 of 6 Posts
