1 - 5 of 5 Posts
Fellow RL members,
Anyone know how to change the dash light bulb under the driver's side temperature control knob on an '06? I assume that you pry the knob off somehow but thought I had better ask before tearing something up. Thanks.
Do a search first. There's a thousand threads on it but you pull the whole dash off and replace them all. One at a time they'll all burn out.
Take off entire dash front cover, unscrew from the back the temp control unit, then unscrew the black unit and lift the tabs on the back to separate the unit in two, bulbs are right there. About $5 each at dealer and east to replace.
Sent from my iPad using Tapatalk
I'd buy led's from superbright or someone. They'll last forever and are cheaper than a dealer.
1 - 5 of 5 Posts
