I've owned my used 2007 RTL for 2 years and ever since buying it I've been doing all that I could do to get the fuel economy to improve. I'd average 15.5 with mostly a mix of heavy suburban driving, with a commute that's 17 miles long and 12 lights.
This is all I did in approximate order: full synthetic 5W20 oil
new air filter
tires to 36 psi
new top Oxy sensors
new pads and rotors- one new caliper, as it seemed jammed
flushed through a whole case of Honda ATF in the tranny
removed and cleaned throttle body and cleaned with CRC & toothbrush
Did idle learn procedure- 3500 rpm until fan came on- not easy solo!
This really did nothing to improve mpg's- until I started the practice of keeping the revs below 2500 rpm.
Then I got 17.15 and 17.32. Then I decided to drive with abandon the next tank, to see if it was really the light pedal that was doing it, and not a result of Idle Learn or the throttle body cleaning- NOPE! Back to 15.5 mpg.
Moral of the story: The Ridgeline is a big heavy truck, and to get that moving you can not do jack rabbit starts to get it rolling.
Sorry, I'm just not buying these guys that are getting 22 and the like, there is something wrong with their math!
Best always,
Bluemill
new air filter
tires to 36 psi
new top Oxy sensors
Best always,
Bluemill
