Hey folks, I have and 09 Ridge. Started to have a bit of an issue about a month ago.
Turning left, once I started to straighten back out would a get a small, clunk, clunk, clunk, from the front end. Would do it rarely. Past two weeks it has been much more consistent. Thought maybe a CV?
Took it to a mechanic this morning, not a dealer only do that if I absolutely must. After about 2 hours he called me explaining that he is having trouble locating the source. Checked everything he could visually inspect and all looks good. Took it over to a Transmission only expert to see if he could help.
They asked if I had, had the diff serviced recently. I explained that I had back in July before a long road trip. They where wondering if the wrong fluid was put in(nope I checked my records). He went on to explain that maybe the clutches in the differential are sticking, which would make sense that the noise comes once you start to straighten out ie: the clutches are trying to release?
Any one have a similar or the same issue? The above make any sense? Suggestions?
