My 2022 Ridgeline has a lot of blind spots and if, like me, you don't have the blind spot monitoring, it's a little frustrating. Also, using the small rear view mirror to look through the small rear window is not that good. I decided to try the NexiGo D90 mirror dash cam and it solved all of my blind spot issues. It's close to $250 and there are lower priced models but I wanted to get the 4k version. It's only 4k for the front camera. The camera takes a little time to get used to viewing a camera as your review mirror but I've had it for about 2 weeks and can't imagine driving without it. I mounted my camera inside the cab but I guess it can be mounted outside. You will see from the pictures, I'm still working to clean up the wiring.
Product: NexiGo D90 4K Mirror Dash Cam
Pros: It is always recording and comes with 128gb memory card. Records front and back with or w/o audio. It has a wide angle view that makes using it as your full time review mirror a lot better than the stock analog mirror.
Pros: Viewing angle can pan up and down so you can see your cargo if you need to.
Cons: At dusk and dawn, I've noticed the camera adjusting the low light. Rear camera pictures seem to have a high contrast so the picture looks different but still very usable. I've only noticed it at those specific times so I've concluded it's the low light. At full night and day, it's perfect in my opinion.
Cons: To have a clean look, you'll have to find a way to run/hide your wires. It's really not that hard. 2 wires need to be connected, power and the rear (included) camera. The optional third cable is a GPS receiver for speed and direction. I didn't use it because I get the same information from my actual Garmin GPS. My Garmin w/Alexa is another of my "must haves".
Cons: The mirror is 11 inches wide so I need to angle the mirror toward the driver so that my visor can fully move down.
Anyway, just thought I would share for anyone with concerns about the blind spots and want a solution
