1 - 11 of 11 Posts
2018 Ridgeline RTL-E
Does anyone know if there is a way in "settings" to make the infotainment display automatically go to night mode after sun goes down and back to day during daytime? Currently I'm having to hit the Moon/Sun button to changes it each time. It's automatic in most other vehicles I've driven Thanks.
Sorry guys but I don't see anywhere in the manual that talks about the display automatically changing brightness from day mode to night mode. I do see a section called Auto Daylight in the System Settings window under Clock - but I think that's for switching automatically to daylight saving time. The only way I know about dimming the display at night is to manually hit the Sun/Moon button on the lower left side of the screen. Does the Ridgeline even have an auto day/night dimming funtion for the display unit? If so what page is it on in the manual?
Thanks.
As someone mentioned, just make sure the dash brightness is not all the way up or all the way down. Those are 'sticky' points. Any where in between will switch night/day automatically
You are looking in the wrong manual. Auto switching is described in the Navigation Manual on page 27 for 2017. The switching follows the headlights. The headlights are controlled by the sunlight sensor on the dash. I am not saying it is well written, but the day/night does switch automatically.
398061
Discussion Starter #8
Yes, I saw that and lowered the brightness below highest settings. Also there is nothing covering the sensor on the middle front of the dash by the window. The brightness still isn't dimking at night unless I manually change it.. I'd still like to see somewhere in the manual that talks about setting the day/night brightness to automatically change respectivly.
Discussion Starter #9
Wow, just noticed your reply. I'll ty it....Thanks!!
Discussion Starter #10
Also, make sure the instrument panel brightness control isn't set all the way up or everything will stay in "day" mode.
Bingo, the stink'n brightness control for the dash panel was set to max brightness. Sliding it dim one bar now allows the infortainment display to auto brightmess between day and night mode. I never would have thought that button controls the infotainment display. Thanks!!!
I've found during the day, if you use a sunshade, the display can get stuck in night setting. I don't know if this is software or dust related, but restarting the truck fixes the problem. It's a pretty rare occurrence.
1 - 11 of 11 Posts
