Hi - I'm new here, but I sure could use some helpful advice. I changed my timing belt myself on my 2006 Ridgeline which uses the J35A9 engine. Near the end of the process I was tired and it was late at night and I made a mistake: I forgot to engage the tensioner on the belt before starting the engine.
The timing belt has skipped/jumped. I've now reset the timing to line up the marks on the crankshaft and two camshafts and engaged the tensioner so the belt is tight and won't skip. I've cranked the engine manually clockwise two times and verified the marks are still in alignment.
The engine now will not start. I've measured the compression thinking it I've done some damage to the engine and most likely bent one or more valves.
Cylinder PSI
1 130
2 145
3 135
4 125
5 65
6 115
So, it looks like cylinder 5 now has bent valve(s) and cylinders 4 and 6 look only slightly lower than the rest. It seems all affected cylinders are on the front head.
Based on what I've read in other posts, I believe I may be able to remove the front head and take it to a machine shop and ask them to fix the damaged valves/guides. Is this the best next step?
Since this happened I have bought a service manual and have the info on how to remove replace the head. I've not done this before though. I could also just have the truck towed to shop to have them fixed my botched job.
Cylinder PSI
1 130
2 145
3 135
4 125
5 65
6 115
