So I have been kind of down on the Ridgeline lately. Its an 07 with 162k, overall its OK but lately its developed some issues that made me rethink holding on to it.
First was the obnoxious suspension knocking going over bumps. It was getting worse and I already had replaced the sway end links. I brought it to my buddy (Toyota Tech) and he was pretty sure it was the struts or upper mounts. Second, the engine developed a loud ticking noise at idle. It was getting worse, I thought I must have screwed up the valve adjustment and it needed to be redone. Then the dome lights stopped working when you open the door. I replaced the bulbs but that didn't help. The last chronic issue was the vibrations at speed. I rotated tired and even replaced U-joints. It was a little better but it still had a substantial vibration.
I was starting to look at other vehicles seriously. But instead of jumping ship I decided to come back here first. With the help of the ROC, here is what I learned and did.
I disconnected the sway bar links and drove on bumpy roads, and viola! The noise was gone! That led me to replace the front sway bar bushings which fixed it permanently. For only four bolts, it took me an hour. No need to drop the cradle or anything crazy.
Researching the engine ticking, loose spark plugs seemed to be a chronic problem. Sure enough three out of six were loose. Ticking gone!
I took the dome light apart (instructions found on the ROC) and determined both the map light switches were bad. I also saved money by ordering them on ebay, thanks to the ROC again. New switches and problems solved.
The majority of the vibrations went away simply by replacing the worn out brake rotors/pads. This was suggested by someone here months ago.
No ticks, clunks, vibrations and the map lights work. Moral of the story, do a little research and keep that old Ridgeline!
Thanks to all!
Thanks to all!
