I recently purchased new drivers side door lock cable..The other end was frayed.. Very easy to do..
Since I could not get 3 Philips head loose holding door modulator, I decided to do it with modulator still in tack..
Steps 1- remove door panel
-pull plastic shield up if applicable
-undo clip end from door handle
-remove 2 plastic pins holding cable to door
-remove window channel bolt
-undo clip @ top of modulator
-undo harnesss
-remove tiny Philips head screw
-pull apart assembly(pulling towards right side
-undo clip from pink holder
-remove old cable and install in reverse!!
-undo harnesss
