72315-SJC-306 and 72355-SJC-306 are the part numbers.
Special Tools Required
KTC trim tool set SOJATP2014*
*Available through the American Honda Tool and Equipment Program; call 888-424-6857
NOTE:
Put on gloves to protect your hands.
Take care not to bend or scratch the trim and panels.
Use the appropriate tool from the KTC trim tool set to avoid damage when prying components.
Pull out the fuel fill door opener knob (A), and detach the hooks (B) from the kick panel (C) and B-pillar lower trim (D), and pull the front door sill trim (E) up by hand to detach the clips (F) and a clip (G) (driver's), then remove it.
If necessary, pull the front threshold trim (H) up to detach the clips (I), then remove the trim.
Remove the kick panel (A).
-1 | Pull out the door opening trim (B) as needed from the kick panel hooks (C) and the door opening flange. |
-3 | Pull the panel out by hand to detach the clip (E), then remove it. Driver's: Pull the panel back to release it from the hood release handle (F). |
- Detach the hooks (A) from the B-pillar lower trim (B) and rear seat side trim (C), and pull the rear door sill trim (D) up by hand to detach the clips (E), then remove it.
- If necessary, pull the rear threshold trim (F) up to detach the clips (G), then remove the trim.
- Remove the B-pillar lower trim.
- Pull out the front door opening trim (A) and rear door opening trim (B) from the trim hooks (C) and around the front and rear door opening flanges, then remove the trim.
- Remove these items:
- Rear seat assembly
- Rear trim panel
- Rear seat belt upper anchor
- C-pillar trim
- Rear seat belt lower anchor
- Remove the clip (A). Pull out the rear seat side trim (B) to detach the clips (C), then remove the trim.
- Install the trim in the reverse order of removal, and note these items:
- Check if the clips are damaged or stress-whitened, and if necessary, replace them with new ones.
- Push the clips and hooks into place securely.
